Just did a quick search on M&H website, sends you over to yearone.
Curious to see what it comes with lately, I like the confidence inspiring words/phrases in the description: most, several, if not all, may vary.
Sounds like a phone call is in order.
Also noticed a dash harness is $800 smackers.
A few years ago I bought an AAW complete harness, fuse box and all, for $300.
Most engine/forward light harnesses include several, if not all of the following connections: temperature sending unit, oil sending unit, coil power, alternator, horn relay wire, washer pump motor, high/low beam headlights, turn signal indicators, and side marker indicators. Other connections may vary depending on your particular model.
