1. dart swanger
    dart swanger Active Member
    43
    28
    Dec 29, 2018
    calgary, AB. Canada
    Local Time:
    11:16 PM
    I have an opportunity to purchase a two Ram trucks. One is a 2004 and the other is a 2006. Both have the Hemi. Which one should I consider buying for my Hemi swapped 69 dart?
  2. tonysrt
    tonysrt FABO Gold Member FABO Gold Member
    544
    217
    Dec 25, 2016
    Northport, NY
    Local Time:
    1:16 AM
    I would check with the pickup forum. They seem to have different problems with different years. I have an 05 with 85,000 miles and no problems. Of course I take care of it. You never know what used has been through, especially if they were leased vehicles.
    • Agree Agree x 1
    • Stephen Mulkey
      Stephen Mulkey FABO Gold Member FABO Gold Member
      317
      160
      Nov 29, 2016
      California
      Local Time:
      10:16 PM
      I agree with Tony. I have an 05 Power Wagon with 283,000 miles. Bought it new and took care of it, with no issues.
    • 408 swinger
      408 swinger FABO Gold Member FABO Gold Member
      1,224
      981
      Nov 12, 2010
      Iowa
      Local Time:
      12:16 AM
      Either is a good engine. Yes, earlier ones had some issues. With extreme lack of maintenance. The 06 will have one coil pack per cylinder. Versus a coil pack and plug wire per cylinder. A little cleaner up top. Otherwise, pretty much same engine.
      • Agree Agree x 1
      • Hellcat Cuda
        Hellcat Cuda Well-Known Member
        542
        43
        Jan 12, 2013
        Northern Calif.
        Local Time:
        10:16 PM
        Also, the '04 does not have MDS whereas they added MDS on the '06 models. You really don't need MDS on a hot rod, but it could be eliminated on the '06.
        Another tid bit tough, if you can get the ECM and harness on the '04, it's pretty easy to use it in your hot rod with any tranny. The ECM on that model year was stand alone, not integrated in with the TCM as the '06 would be. (assuming both trucks are auto trans)
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        Ya both are auto. I want to use a modern trans. So if the 2004 tranny isn't integrated with the engine will a tuner like a flash PAC be worth it to buy? Might just throw a cam and exhaust at it to pep it up ( rebuilt stock suspension with a 8.25" diff with 3.55's). Not lookin for a track monster just a street rod.
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        I also have a buddy with 2006 Hemi 300 with a nag 1. The engine is blown so the 2006 Ram would be a good match for a complete drive train swap (sensors and modules all there). Oh the choice's...lol.
      • 408 swinger
        1,224
        981
        Nov 12, 2010
        Iowa
        Local Time:
        12:16 AM
        The Nag is stronger, but, more complicated to do. You would need a lot of components from the 300 to make it happen. Then there's the drive shaft to deal with. The 545 only needs the computer. Either trans will require floor/t-bar crossmember surgery. Go to Hotwireauto.com for the details on the Nag swap.
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        Was really thinking of purchasing all 3..lol. I can get all 3 for $2400. The 300 has everything I need except it has a blown engine. Figure I could mate the 2006 rams 5.7 to use with the 300 for my swap and part out the 2004's drive train for sale or save it for a future project. All in all I have a big decision to make.
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        So I bite the bullet and bought the 2004 Ram. Now on the hunt for a tail shaft for the tranny
      • 408 swinger
        1,224
        981
        Nov 12, 2010
        Iowa
        Local Time:
        12:16 AM
        Does the 04 have the 545? If so, the tail assembly can be bought new. The really cool part is the trans does not have to be completely disassembled. Unbolt the adapter for the 4wd, bolt on the new assembly. Comes with the shaft in it.
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        Yup 545. Thank god...something simple for once.
      • HemiJeepTJ
        HemiJeepTJ Member
        5
        0
        Nov 1, 2019
        Ogdensburg Ny
        Local Time:
        1:16 AM
        the 04 ECU has 3 control modules for body/engine,,and a standalone ^TCM for the 545 rfe,,the 06 PCM controls entire body and powertrain from 4 circuits built into the module,,the 06 ram pcm has drive by wire,the 03/04 ram has a cable
      • HemiJeepTJ
        HemiJeepTJ Member
        5
        0
        Nov 1, 2019
        Ogdensburg Ny
        Local Time:
        1:16 AM
        2005 ram is the preferred PCM,but the 06 can be flashed
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        Figure everything I need for my swap is everything I can salvage from the 2004 Ram, engine mounts for the conversion and srt Jeep manifolds.... hopefully.
      • 408 swinger
        1,224
        981
        Nov 12, 2010
        Iowa
        Local Time:
        12:16 AM
        Are you using the torsion bars?
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        Hopefully yes.
      • HemiJeepTJ
        HemiJeepTJ Member
        5
        0
        Nov 1, 2019
        Ogdensburg Ny
        Local Time:
        1:16 AM
        the srt8 gr cherokee exhaust manifolds are nice,and I see them alot ,for sale on the Jeep FB pages,in great shape for $200-250. I have a custom set of stainless headers,in my jeep,I think the truck stock exhaust logs would work,if a guy really needed to use 'em,
      • HemiJeepTJ
        HemiJeepTJ Member
        5
        0
        Nov 1, 2019
        Ogdensburg Ny
        Local Time:
        1:16 AM
        I would search your area for a rear whl drive ram truck from 03-08,even tho' they are hard to find,when you do,they are usually cheap for parts,as 95% of trucks were 4x4's. Novak or even Chrysler may have it new as well,
      • 408 swinger
        1,224
        981
        Nov 12, 2010
        Iowa
        Local Time:
        12:16 AM
      • 408 swinger
        1,224
        981
        Nov 12, 2010
        Iowa
        Local Time:
        12:16 AM
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        I've heard they fit and don't fit..lol. If they don't fit I guess a set of TTI is the next step
      • 408 swinger
        1,224
        981
        Nov 12, 2010
        Iowa
        Local Time:
        12:16 AM
        On the SRT, I tried the easy/passenger side first. It will bolt to the head and fit the confines, but, the collector is twisted in such a way that the torsion bar can not be installed. Didn't even bother with the driver side. The 5.7 Grand Cherokee logs(2010-2011) DO fit. They can be had for about 250 bucks. If budget isn't an issue, TTI every time.
      • dart swanger
        43
        28
        Dec 29, 2018
        calgary, AB. Canada
        Local Time:
        11:16 PM
        I will look and see at the local PnP for those manifolds.
