Estimates for 1/4 time?
Mopar Racers Forum
  1. gagembassett
    gagembassett FABO Gold Member FABO Gold Member
    249
    183
    Oct 27, 2021
    Iowa
    Local Time:
    1:17 PM
    I'm working on building a 1983 Dodge D150 for racing. Just curious what people think I will run for a 1/4 mile time this next season. 3,200 lbs. Wide Ratio A833 OD 4 speed. 8 3/4 with 4.10 gears, Custom made Caltrac Style traction bars. Double Adjustable QA1 shocks. New heavy duty truck leaf springs. 1979 360 block bored .030 over, Sealed Power Hypereutectic pistons bringing it up to 9.8:1 compression ratio, 1970 "J" heads (1.88/1.60 valves), Erson RV camshaft (Lift: .420 int/.443 exh, Duration: 270 int, 280 exh, @.050: 204 int/ 214 exh, 112 LSA) advanced 7 degrees for a lot of throttle response and low-end grunt, PBM hydraulic lifters, stock rockers, Weiand Action Plus intake and Carter 625 CFM Competition Carb jetted for 100 octane fuel. Will run 15x10 rims with appropriate fitting slicks.
  2. thesiren74
    thesiren74 Well-Known Member
    2,159
    1867
    Feb 23, 2014
    kenosha,wi
    Local Time:
    1:17 PM
    Mid to high 14s.
    • Agree Agree x 4
    • thesiren74
      2,159
      1867
      Feb 23, 2014
      kenosha,wi
      Local Time:
      1:17 PM
      Cam,carb seem small and that Trans might hurt a little.
      • Agree Agree x 2
      • j par
        j par Well-hung Member
        29,915
        17742
        Jul 2, 2014
        Portland Oregon
        Local Time:
        11:17 AM
        • Like Like x 1
        • Agree Agree x 1
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          86,618
          69009
          Jun 7, 2010
          Georgia
          Local Time:
          2:17 PM
          Couple days.
          • Like Like x 1
          • Cudafever
            Cudafever Well-Known Member
            4,701
            1794
            Sep 27, 2009
            Local Time:
            12:17 PM
            Run what you brug. It sound like a lot of fun.
            Injoy what you have.
            • Like Like x 1
            • Cudafever
              4,701
              1794
              Sep 27, 2009
              Local Time:
              12:17 PM
              The et don't matter. Its a base line for you to build on.
              I'm going to say 17s........ when you get it all worked out. learning how too leave the line with a standard will be the biggest et improvement.
              • Like Like x 1
              • Agree Agree x 1
              • 318willrun
                318willrun Utube channel 318willrun
                19,413
                23135
                Sep 13, 2013
                I'm here
                Local Time:
                1:17 PM
              • 318willrun
                19,413
                23135
                Sep 13, 2013
                I'm here
                Local Time:
                1:17 PM
                subscribed
              • j par
                29,915
                17742
                Jul 2, 2014
                Portland Oregon
                Local Time:
                11:17 AM
                I didn't think you'd want to miss this one by accident...
                • Like Like x 1
                • 318willrun
                  19,413
                  23135
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  1:17 PM
                  Ok, I'll play. If it only weighs 3200 lbs, that's A-body light! 4.10 gears. A mild but stout 360. 4 speed, so he can leave at any RPM he likes (as long as it has traction). I'll say 12.77. He's a few hundred pounds lighter than DT :D
                  • Like Like x 2
                  • j par
                    29,915
                    17742
                    Jul 2, 2014
                    Portland Oregon
                    Local Time:
                    11:17 AM
                    He'll probably finish the quarter mile and second gear depending on how tall is tires are... It's an overdrive for speed...
                    • Like Like x 1
                    • Agree Agree x 1
                    • 318willrun
                      19,413
                      23135
                      Sep 13, 2013
                      I'm here
                      Local Time:
                      1:17 PM
                      I wish DT had one, it'd help for highway cruis'n. I'd lower my 60 ft with it too
                    • j par
                      29,915
                      17742
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      11:17 AM
                      DT?...
                    • 318willrun
                      19,413
                      23135
                      Sep 13, 2013
                      I'm here
                      Local Time:
                      1:17 PM
                      Drag Truck
                    • gagembassett
                      249
                      183
                      Oct 27, 2021
                      Iowa
                      Local Time:
                      1:17 PM
                      I'm not trying to be a smart-ass as I tend to genuinely have trouble being able to tell the difference, but is this a serious reply or a sarcastic one?
                      • Like Like x 1
                      • j par
                        29,915
                        17742
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        11:17 AM
                        Bahaha...
                      • 318willrun
                        19,413
                        23135
                        Sep 13, 2013
                        I'm here
                        Local Time:
                        1:17 PM
                        Both. I have a '80 D150 that kind of is similar to your build. My truck is a bit heavier than yours, and I ran 8.2's in the 1/8, which would be about 13.15 with the truck and wind resistance. But, folks are all over with their builds, so I have no idea what you may actually run, so I threw out 12.77 :)
                        • Like Like x 1
                        • j par
                          29,915
                          17742
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          11:17 AM
                          Oh.. mine is CP...
                        • 318willrun
                          19,413
                          23135
                          Sep 13, 2013
                          I'm here
                          Local Time:
                          1:17 PM
                          CP ?
                          • Like Like x 1
                          • j par
                            29,915
                            17742
                            Jul 2, 2014
                            Portland Oregon
                            Local Time:
                            11:17 AM
                            Cream Puff...
                            • Like Like x 1
                            • gagembassett
                              249
                              183
                              Oct 27, 2021
                              Iowa
                              Local Time:
                              1:17 PM
                              Gotcha gotcha. Sorry don't mean to sounded big headed or anything. I appreciate the info!
                              • Like Like x 2
                              • 65 Cuda 340
                                65 Cuda 340 FABO Gold Member FABO Gold Member
                                955
                                1370
                                Dec 27, 2019
                                Tallahassee Florida
                                Local Time:
                                2:17 PM
                                According to Camcraft, specs for a stock 340 cam are 210/220 at .050. If that's accurate, your cam has six degrees duration less than a stock 340 cam. Kinda doubt that Weiand intake is any better than the stock 340 intake; but your carb is a little bit bigger. On the plus side, you do have an extra 20 cubes over a 340, and your truck is pretty light. And with the right gears and with traction, I could see a 340 A body that's stock except for headers dipping into the 13's.
                                • Like Like x 1
                                • 65 Cuda 340
                                  955
                                  1370
                                  Dec 27, 2019
                                  Tallahassee Florida
                                  Local Time:
                                  2:17 PM
                                  • Like Like x 1
                                  • GTX JOHN
                                    GTX JOHN FABO Gold Member FABO Gold Member
                                    1,011
                                    913
                                    Dec 12, 2009
                                    Boulder City NV.
                                    Local Time:
                                    1:17 PM
                                    Ten years ago my 82 Dodge D150 @ 3885 lbs. - Stock 360 Thermoquad /stock heads /cam /intake/8.6 Compression.
                                    Torqueflite with 456 gears = Set NHRA National Record N/SA 2 12.12 @ 107 MPH.
                                    This was a well prepared and put together stock truck! It had been as fast as 11.70 after that in class.
                                    I do not know how I could of got it down to 3200 Lbs? It is a big vehicle.
                                    • Like Like x 5
