Estimates for 1/4 time?
Mopar Racers Forum
  1. j par
    j par Well-hung Member
    29,786
    17617
    Jul 2, 2014
    Portland Oregon
    Local Time:
    4:42 PM
    @318willrun ^^^ looks like you may have a long road ahead of you.. LOL..
  2. Mopar Sam
    Mopar Sam Well Fed Member
    1,604
    2453
    Jul 18, 2008
    Indiana
    Local Time:
    7:42 PM
    Since there are a few of us here building trucks, can you share how you got yours so light? I know I would welcome any ideas.
    • Like Like x 1
    • Agree Agree x 1
    • thesiren74
      thesiren74 Well-Known Member
      2,113
      1788
      Feb 23, 2014
      kenosha,wi
      Local Time:
      6:42 PM
      If that's the truck in your avatar yeah I'm not sure that's 3,200 lbs...
    • 318willrun
      318willrun Utube channel 318willrun
      19,275
      22857
      Sep 13, 2013
      I'm here
      Local Time:
      6:42 PM
      ?? Not sure what you mean.. My road has been fun, and continues to be fun. No end or destination. But this thread isn't about my truck. Have a guess what the OP will run ??
    • Dartswinger70
      Dartswinger70 Awww man...
      4,006
      2377
      Sep 20, 2005
      Southeastern Pa.
      Local Time:
      7:42 PM
      If it had wings it would fly...
    • gagembassett
      gagembassett FABO Gold Member FABO Gold Member
      207
      145
      Oct 27, 2021
      Iowa
      Local Time:
      6:42 PM
      ran it across a grain station elevator scale with dad and I in it, 3,700 pounds on the screen. I'm 185. He's around 300+. There's the math.
      • Disagree Disagree x 1
      • gagembassett
        207
        145
        Oct 27, 2021
        Iowa
        Local Time:
        6:42 PM
        I haven't done anything to the truck other than swap it from a 225 Slant 6 to the 360 and swap the 8 1/4 out for the 8 3/4. If I knew I would tell you, but the grain elevator scale showed 3,700 pounds with my dad and I in it. Subtract our weights and it would be around 3,200. Maybe I should check for heavy rust weight loss LOL. If I had an explanation I would gladly give it to you.
        • Thanks! Thanks! x 1
        • 318willrun
          19,275
          22857
          Sep 13, 2013
          I'm here
          Local Time:
          6:42 PM
          My guess is the scale is in question. IF yours is a long bed with p/s, I'd guess it's around 3700+ without spare, jack, and a 1/4 tank of gas. I've lighten my '80 long bed up a bit, and it's back up to about 3600 (we had it to 3500)
          • Agree Agree x 1
          • gagembassett
            207
            145
            Oct 27, 2021
            Iowa
            Local Time:
            6:42 PM
            very well could be. I can definitely drive across again and double-check. I have no reason to hide anything and if it was a false read then so be it! I'll just have to go bigger and better to be faster lol
            • Like Like x 1
            • 318willrun
              19,275
              22857
              Sep 13, 2013
              I'm here
              Local Time:
              6:42 PM
              Nobody thinks your hiding anything. Some of us have weighed enough trucks to know approx. weights. IF you had yours down to 3200, we were going to pick your brain for tips !!! Is yours a long bed or short bed ?? I have a 360, 727, and 8.75 in mine. Things I did to lighten mine up are: I took out carpet, heater box, rear bumper, front bumperettes, spare tire holder, replaced both bigger mirrors for one small car mirror, the extra wiring under the hood that I wasn't using, radio and speakers, anything loose not in use, and went manual steering. We had it at 3500 lbs but then went to the 8.75, put the steel wheels back on it, replaced the 318 with a 360, and added traction bars. We are about at 3600 figuring in my head.
              • Like Like x 3
              • Agree Agree x 1
              • gagembassett
                207
                145
                Oct 27, 2021
                Iowa
                Local Time:
                6:42 PM
                In all actuality I have already done most of the things you listed as well! When I built the 360 and put it in I removed a massive amount of wiring to make it look cleaner in there, carpet was removed a long time ago due to rot and it was now green and no longer red LOL. Heater box is still there to help evacuate heat from the engine. Spare tire holder was never there when my dad got the truck 20 years ago, must've been removed by previous owner. Same as well with anything loose and not using. I tend to remove the tailgate when I do any racing for aerodynamic reasons so there's maybe 50-75 pounds? Or more? I have no clue what that would weigh. Somewhat close but not perfectly exact to what you have done. Sounds more and more like the scale gave off a false reading
                • Like Like x 2
                • 318willrun
                  19,275
                  22857
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  6:42 PM
                  Nice. I saved almost 40 lbs by going to manual steering. My tailgate is still on, and will stay on. It's my wife's favorite part of the entire truck, she loves the decal, plus it gives the clean look/farm truck (although she's plenty rusty :D) Just curious, have you had it to a drag way previously ?
                • gagembassett
                  207
                  145
                  Oct 27, 2021
                  Iowa
                  Local Time:
                  6:42 PM
                  To legitimate drag races? Not yet! I have taken it to unofficial airport drag races and I could not get it to hook for the life of me. That's where all of the traction and suspension upgrades came from and that's what got the cogs turning on ET's
                  • Like Like x 2
                  • 318willrun
                    19,275
                    22857
                    Sep 13, 2013
                    I'm here
                    Local Time:
                    6:42 PM
                    Especially long beds, they are miserable to get to hook up with any power at all. Ask me how I know.... and don't even ask me to explain what I did to end wheel hop :D :D
                    • Like Like x 1
                    • 33IMP
                      33IMP Well-Known Member
                      2,628
                      2792
                      Jul 3, 2020
                      Taxifornia, soon 2b arizona
                      Local Time:
                      4:42 PM
                      In my humble opinion, first step in getting a vehicle to hook, is get the biggest pair of real slicks on it that fit. Not dual purpose street/strip tires. Get whatever wheels it takes to get them under the car/truck, and swap em at the track.
                      That is the best starting point for further tuning. If your spinning your tires, you are just spinning your wheels, metaphorically.
                    • Mopar Sam
                      1,604
                      2453
                      Jul 18, 2008
                      Indiana
                      Local Time:
                      7:42 PM
                      Be sure to keep us updated. Trucks are fun to work with.
                      The first lbs. off are pretty easy, then you have to really work for it! I ate a lot of metal chips grinding off frame rivets for removing some brackets and a crossmember. I removed my parking brake lever/cables for about 14lbs. I liked the look of the original radio, so I gutted the case and saved about 3#s.
                      I'll be watchin your thread.
                      • Like Like x 1
                      • gagembassett
                        207
                        145
                        Oct 27, 2021
                        Iowa
                        Local Time:
                        6:42 PM
                        What everyones thoughts on if I switch to 4.30 gears instead? Any ET gain?
                      • 318willrun
                        19,275
                        22857
                        Sep 13, 2013
                        I'm here
                        Local Time:
                        6:42 PM
                        4.10's to 4.30's is really splitt'n hairs at this point. Just my opinion
                        • Agree Agree x 2
                        • Like Like x 1
                        • gagembassett
                          207
                          145
                          Oct 27, 2021
                          Iowa
                          Local Time:
                          6:42 PM
                          Kinda what I thought
