dare_dude
Active Member
Just wondwering what kind of ETS you folks are running with iron heads ported or unported? Also what is your combo?
dare_dude said:Just wondwering what kind of ETS you folks are running with iron heads ported or unported? Also what is your combo?
moper said:A good set of iron heads will be close money wise to a set of new aluminum heads. Especially ported. It comes down to airflow, and the "whole package". You dont need much airflow to run well if the package is efficient at accelerating. So iron heads can carry you way into the 11s and probably closwe to 10s with moderate porting on a 340/360 build prety easy. But they will cost close to the same $$ as a set of RPMs, and the RPMs are lighter, have a better chamber design, and have more potential for future growth.
Moparmal said:Moper - So other than a fully ported set of J's....or 308 close chambers...are Eddies the only other cost effective option?..Lets say at under $1500 US?
I started a thread maybe a month or two ago talking about at these new price levels it doesn't make sense to put money into cast iron heads especially when you can get a fully loaded set sent to your door for $703... I have way more into that into my 596 heads.. K line valve guides, stainless steel 202 valves, Crower Springs, chromoly retainers, competition valve job, a couple hours Shop Port time, plus days worth the porting of my own...Boy how times have changed! And here’s another one, interesting how things were back then:Small Block heads W2,5, Aluminum
The only way of getting my money and time back out of them is to reuse them again on something else..
