"EVERY A body has this problem"
Mopar Body and Trim
  1. UDUST81
    UDUST81 Well-Known Member
    472
    172
    Jan 5, 2014
    Des Moines IA
    Local Time:
    4:59 AM
    • Like Like x 1
    • Agree Agree x 1
    • marksmopar1
      marksmopar1 Well-Known Member
      667
      145
      Feb 21, 2014
      Winnipeg, Canada
      Local Time:
      4:59 AM
      Yup....nearly every A body I have had....Been there done that!
      • Agree Agree x 1
      • BigBlockMopar
        BigBlockMopar BigBlockMember
        1,739
        735
        May 1, 2011
        Netherlands
        Local Time:
        11:59 AM
        Goes right along with the frame rail cracking at the K-member.
        • Like Like x 1
        • stroked340
          stroked340 FABO Gold Member FABO Gold Member
          4,586
          1378
          Jun 14, 2014
          mass.
          Local Time:
          5:59 AM
          Have owned 4 A-bodies never ever had this issue..
          • Agree Agree x 2
          • GeorgeH
            GeorgeH Well-Known Member
            8,530
            3255
            Sep 23, 2014
            laurel delaware
            Local Time:
            5:59 AM
            Yep,on my 75
            Saw some cracking and cleaned it off. It had been welded before.
            Cut it out. I was able to clean up and reuse the cage for the nut and weld it back on. used same material thicknesses for the repair
            Granted the qtr was off and I was able to get to both sides to weld the 2 plates in easily.
            • Like Like x 1
            • TF360
              TF360 Well-Known Member
              1,410
              393
              Apr 25, 2014
              Florida
              Local Time:
              5:59 AM
              I have owned 8 A- bodies- None of mine broke-That's nonsence
              • Agree Agree x 1
              • Disagree Disagree x 1
              • GeorgeH
                8,530
                3255
                Sep 23, 2014
                laurel delaware
                Local Time:
                5:59 AM
                The biggest thing that causes this is when the bushings are shot and the door is hanging on the striker. I have done enough on all makes and the repair usually starts with bushings and re-aligning the door.
                • Agree Agree x 1
                • coalman
                  coalman Well-Known Member
                  878
                  209
                  Aug 6, 2015
                  Texas
                  Local Time:
                  4:59 AM
                  My first "A" Body was a 1969 Swinger 340 4 speed which I ordered in 1969 or 68 can not remember for sure, old age. I had this problem on the drivers door. The large washer had the sharp side on the body, and was cutting it. I got a larger washer, put the smooth side on the body, it worked fine and lasted a long time...
                  • Like Like x 2
                  • DavidLee
                    DavidLee Well-Known Member
                    329
                    71
                    Aug 1, 2011
                    Torrance, CA
                    Local Time:
                    2:59 AM
                    my 67 does not have this problem at all
                  • CodyS
                    CodyS Well-Known Member
                    207
                    91
                    Mar 1, 2013
                    South Dakota
                    Local Time:
                    4:59 AM
                    I have seen more a bodies with this problem than ones without.
                  • mycuda
                    mycuda FABO Gold Member FABO Gold Member
                    5,373
                    2695
                    Feb 15, 2011
                    Chicago/ Metro
                    Local Time:
                    4:59 AM
                  • RPMagoo
                    RPMagoo Just An Old Motorhead
                    2,937
                    1388
                    Nov 4, 2015
                    N.E. Pa.
                    Local Time:
                    4:59 AM
                    "EVERY A body has this problem" ???? -- I've had 5 of them, without this problem.
                  • 1969VADart
                    1969VADart FABO Gold Member FABO Gold Member
                    2,205
                    512
                    Aug 19, 2013
                    Fredericksburg, VA
                    Local Time:
                    5:59 AM
                    I discovered when we stripped my Dart that the door striker mounting location had been reinforced on both doors on my car with a piece of metal riveted in (not the way it came from the factory).
                  • MoparLeo
                    MoparLeo NRA PATRON LEVEL LIFE MEMBER
                    440
                    255
                    Feb 10, 2016
                    Moreno Valley, Cal. So. Cal.
                    Local Time:
                    2:59 AM
                  • LocuMob
                    LocuMob Fluid Technician FABO Gold Member
                    1,679
                    961
                    Oct 30, 2013
                    Southern Mn
                    Local Time:
                    4:59 AM
                    Mine does.
                  • rumblefish360
                    rumblefish360 So close, yet so far away
                    36,736
                    8551
                    Jun 21, 2005
                    New York, on a Island
                    Local Time:
                    5:59 AM
                    My Duster has this issue, badly!
                  • 72bluNblu
                    72bluNblu FABO Gold Member FABO Gold Member
                    9,910
                    4214
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    2:59 AM
                    Can't be every A-body, none of my current 3 has this issue.
                  • AJ/FormS
                    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
                    17,125
                    5647
                    Jan 19, 2014
                    South-Central Manitoba,Canada, 900ftelevation
                    Local Time:
                    4:59 AM
                    I bought a used Swinger 340 in fall of 70. By 73 or 74, I had to have this repair done.I think I got it done on warranty,lol. I think if you don't drive them then they don't break,lol. I wore everything out on that car, some stuff, twice!Except tires. Man that car ate tires.And synchros.
                    After that I learned to adjust the door hinges more often and to not lean on the open doors.
                    I've had many As that were cracked there , from 40% say all the way to 100%. Actually the more I think about it I can't remember but three of them not being cracked, out of say at least 10.
                  • 273
                    273 Well-Known Member
                    2,933
                    718
                    May 14, 2012
                    Ontario
                    Local Time:
                    5:59 AM
                    Thanks, my car needs that repair, good info
                  • Abodybomber
                    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
                    31,729
                    10475
                    May 21, 2011
                    Arroyo grande ca
                    Local Time:
                    2:59 AM
                    That's why, this forum exists...( lol...)..
                    • Like Like x 1
                    • 68cuda408
                      68cuda408 FABO Gold Member FABO Gold Member
                      488
                      144
                      Jun 4, 2013
                      11967 NY
                      Local Time:
                      5:59 AM
                      I bought my shell with the right side striker gone and a hole where the base completely cracked out, the left was nearly as bad. I did the plates and highly recommend them. Of course complimented with new hinges.
                    • famous bob
                      famous bob mopar misfit FABO Gold Member
                      14,733
                      5083
                      Aug 14, 2011
                      okla
                      Local Time:
                      4:59 AM
                      My 68 fastback had worn d.s. hinges before paint, and didn`t have that problem. So not all A bodies have this problem!
                    • 68cuda408
                      488
                      144
                      Jun 4, 2013
                      11967 NY
                      Local Time:
                      5:59 AM
                      No dispute there, A lot of us are victims of previous lack of maintenance, accident damage and poor repairs. My '68 Coronet had spider cracks running from the receiver style striker all the way to the inner flange where the windlacing is. After stripping the quarter I found it was hit low behind the jamb years before and not properly brought back to place, stressing the jamb when the door was shut.
                    • RedFish
                      RedFish Well-Known Member
                      23,663
                      2406
                      Sep 5, 2007
                      Local Time:
                      5:59 AM
                      Where the door hinges wear, the door to sags. Then the latch post lifts door weight when the door is closed. It wasn't engineered/meant to carry any weight. Sure this issue is more common in 2 door cars, having longer heavier doors but it is not limited to one brand or body. How many of you have owned a GM product with a pizzy pull strap on the inside of the door and broke one end of that strap away from the door? They're all the same but different. We've never pulled what we grab off the inside of our doors. None are built like Sherman tanks.
                      Door hinges were supposed to be lubed regularly. Actually, The mfgrs expected the vehicles to visit to their service dept' regularly for routine maintenance which would have included door hinge lube.
                      My 67 fish is in very good condition overall. Credit goes to the previous original owner.
                    • FJRdoc
                      FJRdoc FABO Gold Member FABO Gold Member
                      1,039
                      465
                      Dec 29, 2009
                      Brownstown, PA
                      Local Time:
                      5:59 AM
                      I agree with Redfish. Sagging door hinges is the main culprit to striker failure. My Duster had a cracked striker on the driver's side. The broken striker made a very annoying rattle whenever you would driver over bumps.
