70Duster440
Kinda hoping 67Dart273 will chime in here.
Awhile back I replaced the ignition switch for no other reason than a maintenance upgrade to the electrical system. Cleaned up bulkhead connections while I was at it. Everything seemed fine and dandy except since then I notice an intermittent problem with the Ignition 1 circuit right at the column connector (DBL*). Car would start but then shut off as soon as the key hit the run position. Pull the connector apart, plug it back together, problem "fixed" for awhile. Then I noticed heat discoloration at that cavity of the connector and that it was getting hot to the touch.
My conclusion was a poor barrel connection. I pulled the two terminals out of the connector and plugged them together so I can better monitor them.
My question is, aside from possible resistance at the connector itself, is it possible there's a fault somewhere else causing excessive current flow through the circuit causing it to overheat? If so, where would the likely culprit be?
