Exhaust manifold hardware- Can anyone suggest a source?
MRGTX
CT, USA
I'm back to concentrating on my Magnum swap and sill in the ever-lasting phase of buttoning everything down before hooking up the battery and turning the key. :cheers:
I am reusing the stock manifolds from my 318 and I'm lacking some confidence in the original hardware...
Can anyone point me in the direction of a kit? IIRC, the bolts are various lengths due to the shape of the casting.
Is there anything that needs to be considered since this are Magum heads or would the original bolts do the job?
Thanks for any help!!
-Mike
Try Mancinni Racing, thath where I got mine for my 340 HP stock cast manifolds
Hey MRGTX.
I recently completed a EQ Magnum head swap on my 318 powered 68 Coronet Wagon. I re-used the stock manifolds (temporarily - have Magnum manifolds standing by). For the 4 studs I used Dorman (5/16-18 x 5/16-24 – 1 3/4") part # 675-092.
For the bolts I went the Home Depot route for their grade 8 stuff. I measured each one and used either 5/16-18 1 1/2" or 1 1/4". Hope this helps,
Ernesto
