Feb 27, 2023 #1 M mike240 Well-Known Member Joined Aug 21, 2019 Messages 306 Reaction score 385 Location AZ Has anyone with a torsion bar eliminated suspension (HDK etc) cut out the torsion bar opening housings, reinforced the frame crossmember with a three inch tube to run exhaust through it? Pros…cons? Just kind of occurred to me. More clearance.
Feb 27, 2023 #2 64mopar Well-Known Member Joined Apr 14, 2019 Messages 515 Reaction score 794 Location PittsBurgh Couple of different thoughts.. . 1, you are moving the exhaust close to the floorboard. 2 ,You will definitely have to do adequate rein forcing of that cross member
Feb 27, 2023 #3 HemiSSDart Dartus Interuptus Joined Feb 20, 2013 Messages 3,895 Reaction score 4,198 Location Illinoisy Rattling, heat, and reinforcement, all possible to overcome just how much work do you want?
Feb 27, 2023 #4 M mike240 Well-Known Member Joined Aug 21, 2019 Messages 306 Reaction score 385 Location AZ Still considering power and trans. Possible 4l60. So if I have work to do anyways….
Feb 27, 2023 #5 Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 15,690 Reaction score 17,777 Location Danielsville Pa. 18038 Use mandrel bent down pipes clock them to fit and weld here is 3 1/2 passing through.
Feb 27, 2023 #6 cudascott It’s a sickness! Joined Jan 11, 2012 Messages 2,317 Reaction score 1,187 Location TN unless you are running factory manifolds you aren’t gaining any ground clearance doing that.
Feb 27, 2023 #7 M mike240 Well-Known Member Joined Aug 21, 2019 Messages 306 Reaction score 385 Location AZ Thanks guys. Just a random thought while taking a break and staring at it
