Extra clearance 440 Main Bearings
Discussion in 'Mopar Performance Issues' started by simon1mopar, Jan 21, 2018.
  1. simon1mopar
    simon1mopar Member
    5
    0
    Aug 19, 2014
    perth australia
    Local Time:
    2:40 PM
    Can anyone advise a manufacturer and part number for a standard 440 crank .001" extra clearance main bearing. I can't find one , my current clearance is only.0015" and I want .0025"
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    13,087
    2844
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    1:40 AM
    • Like Like x 1
    • famous bob
      famous bob mopar misfit
      11,004
      2665
      Aug 14, 2011
      okla
      Local Time:
      12:40 AM
      you can get them from Summit racing, I did.
    • Demonic
      Demonic Well-Known Member
      333
      140
      Mar 21, 2015
      Maryland
      Local Time:
      1:40 AM
      You're going for a race clearance? You know, .0025 is the max, the spec is .0005" - .0015" from the FSM.
    • bOb shingler
      bOb shingler Well-Known Member
      3,253
      152
      Jun 8, 2007
      warrenton, north carolina
      View My Photos
      Local Time:
      1:40 AM
      hemi bearings.
    • brian6pac
      brian6pac Well-Known Member
      3,010
      1504
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      1:40 AM
      Don't go less than .0025. Clevite has them for sure.
    • brian6pac
      3,010
      1504
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      1:40 AM
      Looks like NLA from king or clevite, polish the crank down .001"
    • BigBlockMopar
      BigBlockMopar BigBlockMember
      1,537
      483
      May 1, 2011
      Netherlands
      Local Time:
      7:40 AM
      I don't see why you would want 20 years of wear already on the bearings. Just so one can(needs to) run 20W50 oil?
    • brian6pac
      3,010
      1504
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      1:40 AM
      Go ahead and run .001 clearance and 0W20 oil and when you spin a main and waste the block I'll still be running mine 7000 rpm with straight 40W
      • Agree Agree x 1
      • simon1mopar
        simon1mopar Member
        5
        0
        Aug 19, 2014
        perth australia
        Local Time:
        2:40 PM
      • simon1mopar
        simon1mopar Member
        5
        0
        Aug 19, 2014
        perth australia
        Local Time:
        2:40 PM
        agreed, street and race are totally different requirements, I'm running 7200rpm and 14-1 compression, like you say you'll definitely spin a bearing with standard clearance. These old girls aren't manufactured to the tolerance of the new gen engines that will live with tighter clearances
      • simon1mopar
        simon1mopar Member
        5
        0
        Aug 19, 2014
        perth australia
        Local Time:
        2:40 PM
        Yeah thanks Brian, just musn't be much call for them and they've stopped manufacturing. My old crank was 10under and polished so not a problem but it's now a two piece crank and not working so well!
      • simon1mopar
        simon1mopar Member
        5
        0
        Aug 19, 2014
        perth australia
        Local Time:
        2:40 PM
        Yeah thanks, going for a race spec
      • famous bob
        11,004
        2665
        Aug 14, 2011
        okla
        Local Time:
        12:40 AM
        street hemi`s came out of the factory w/ .003 straight across the board, that tell u anything ? I have about .0025 on my 505, and would rather had a hair more. I don`t think we even have decent crank man around here anymore, so what are u to do except added clearance bearings ?
        • Thanks! Thanks! x 1
