plumkrazee70
I have a Denso Alternator with the denso 3 wire plug.
The EZ wire has:
Alternator power
Alternator bypass (for use with alt over 80 amps)
Alternator Excitor wire
The Denso has three wires:
12V reference
12V Switched
Dash light or gauge (if used)
I will be using the bypass wire from: Alternator power stud -> starter wire
My question is can I used the Alternator power wire as my 12V refrence and the excitor wire for my 12V switched power?
Thanks in advance! I am getting closer, the rear of the car is done and I am getting closer to finishing up the underhood wiring, then its on to inside.
The EZ wire has:
Alternator power
12V reference
12V Switched
