ez wiring headlight switch help
mopardemon340
WI
im trying to figure out how to wire this head light switch and im confused.. dose anyone know how to wire it with a ez 21 wire harness. where does the dimmer wire go dose that go to the kick switch or to what terminal on the dash switch. also how do i wire the kick switch... i got the high beam ind figured out.. but the power and the other wire i have no clue.
I did my 68 fastback w/ an EZ. The dimmer switch had 3 wires on the factory plug in, was no problem , so I don`t remember a whole lot about it. I had to convert all the dam chevy stuff over to mopar on the plug ins. where I had my biggest trouble was on the ignition switch, had to tie 3 wires together to power up the msd.,and fuel inj.system. A factory wiring diagram will help on the small stuff. ---call EZ and see if Sean is still there, he`s one smart dude!! let me know what u do when you get to the ignition to power it up, I kept a few notes, if I can find them--------bob
I'm rewiring my 75 Duster using the EZ 21. The dimmer wire goes to the head light switch in the dash (to the headlight out terminal). From there it's prewired to the 3 prong switch that plugs into the kick switch on the floor.
