Fabricated Aluminum Valve Cover
Small Block Mopar Engine
  1. SBeeMan
    SBeeMan Well-Known Member
    169
    15
    Jan 19, 2013
    Crossnore NC
    Local Time:
    4:28 PM
    Who makes a good fab aluminum valve cover for small block Mopar?
    I've tried the $80.00 e-bay covers,got oil coming out of the bolt tubes.
    Not looking for $300 buck plus covers either.
  2. pishta
    pishta I know I'm right....
    13,710
    3434
    Oct 13, 2004
    Tustin, CA
    Local Time:
    1:28 PM
    what kind of gasket are you running for this oil percolation?
  3. SBeeMan
    169
    15
    Jan 19, 2013
    Crossnore NC
    Local Time:
    4:28 PM
    Moroso Perm-Align gaskets
    Strange thing is just got three bleeding oil,all on the bottom.
    I pulled the covers,poured a little oil in them and they are not leaking around the top of the tubes at the welds.
    Takes about 5 min. for the leaking to start.
    Running a HV pump,75psi @ idle hot,15-40 oil.
  4. '63GT
    '63GT Well-Known Member
    453
    364
    Jun 9, 2018
    Turlock, CA.
    Local Time:
    1:28 PM
    A friend of mine had similar issues.. He finally used some fiber gaskets under the heads of the bolts.
  5. SBeeMan
    169
    15
    Jan 19, 2013
    Crossnore NC
    Local Time:
    4:28 PM
    I was thinking of trying to make gaskets for them.
    A Holley bowel screw gasket looks like a close fit.
    Did he make his or something he bought?
  6. '63GT
    453
    364
    Jun 9, 2018
    Turlock, CA.
    Local Time:
    1:28 PM
    I think he used some round fiber gaskets out of a faucet repair kit.. from Harbor Freight, maybe?
  7. brian6pac
    brian6pac Well-Known Member
    3,171
    1693
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    4:28 PM
    What pcv are you using ? if you have a vacuum in the crankcase there should be no leaks! Sounds like you have pressure in the crankcase.
  8. mopardude318
    mopardude318 Well-Known Member
    10,826
    428
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    1:28 PM
    Man I was gonna say those Moroso valve covers are real nice but you said nothin over 300. Think they go for $400. lol.
  9. rustycowll69
    rustycowll69 Well-Known Member
    1,690
    647
    Feb 19, 2016
    Pacific northwest
    Local Time:
    1:28 PM
    Am I the only one that thinks that's a lot of oil pressure, hot, at idle no less?
    • Agree Agree x 3
    • jimjimjimmy
      jimjimjimmy lobsterman FABO Gold Member
      4,066
      853
      Nov 2, 2010
      p. e. i.
      Local Time:
      5:28 PM
      I agree with you but the high pressure is not causing the leak .
    • Dartish
      Dartish Well-Known Member
      600
      267
      Sep 26, 2016
      Iowa
      Local Time:
      3:28 PM
      I bought a set from KMJ Performance. Used fel pro gaskets and never had a leak of any kind on a daily driver. Think they were like $85. I wouldn't hesitate buying another set 0330170236.jpg
    • SBeeMan
      169
      15
      Jan 19, 2013
      Crossnore NC
      Local Time:
      4:28 PM
      It's a new bracket car build,I'm using a Mr Gasket pan evacuation.
      This was during the brake-in of the new stroker motor.
      I was mistaken about the pressure,75 psi cold,60 psi hot at idle.
      These are the KMJ Performance covers I'm using.
      This afternoon I put some hard Holley bowel gaskets under the bolts with Right Stuff sealer.
      I'll fire it tomorrow see if it stopped the leaks.
    • rustycowll69
      1,690
      647
      Feb 19, 2016
      Pacific northwest
      Local Time:
      1:28 PM
      true, to a point. But maybe between the high oil pressure and HV oil pump, he''s throwing so much oil around the valve cover he's overcoming a poor sealing situation and making it worse. The previous suggestion that maybe the engine is pressurizing not evacuating because of an inoperable PCV system, poor ring seal, or "what have you" is a possible factor, too. Just spit-balling, here.
