Factory BB Kframe
4spdragtop
Ontario Parts Unknown
I have an opportunity to buy a factory BB kframe. With what you see attached.
Opinions as to the value?
Thanks
Guess I am in for an education.... I thought all BB's in factory A body's had manual steering.... Learning something new everyday.
JW
Thanks guys, those were only pics I took.
I'm going by what I was told by him. I trust the gentleman, maybe he was misinformed?
I should have looked a little closer :BangHead:
I have put BBs in Abodys with a SB K frame without a problem a few times. Maybe the car had that done to and he didn't know .
To use a small block k-frame with a big block you have to cut a chunk out of the motor mount pad to clear the oil pump. I have had half a dozen like that and currently have a 69 GTS 340 4-speed convertible that has that modification because it had a 383 in it when I bought it. The k-frame above is definitely a small block.
Well as it turns out, it is a sb kframe with BBP kelsey hayes. No sweat from the seller, hes a good guy. I cant use them, but if a member is interested in this setup complete?
