Thanks, I do live in a beautiful part of the country here.
I have no idea what the gear ratios are. Should they have a tag on the outside?
Dallas
yes sir a tag under a cover bolt with three digits 245, 276, ???
Dallas
Fehlhafers inc.
800-742-7370
edgar motor co. Inc.
800-666-3315
capital city auto recyclers
402-475-2982
singer auto parts
877-611-4707
jim defreece auto parts
800-752-2886
olston's auto recyclers
800-223-7020
According to the info I have, the LBP 73+ 7.25 rears are 1.8" shorter flange to flange than the 72 back rears. Might make a difference if you are already tight on real estate under your car for tires.....
The 73+ 7.25 rear flange to flange is listed at 51.4"
72 back is listed at 53.2"
Interesting though, they list all 8.75 a-body rears and 73+ 8.25 and 7.25 at 53.2"
I'm not sure that is correct but I will find out. Another factor to consider is how far the axle extends out from the housing flange. Wheel location could be within a 1/4 of same. I will find out.
So housing length is all that changed. Perch location and wheel location remains about the same
Here is another tidbit of information you might find interesting.
This is a TSB on the 73 A-bodies showing the front end and the rear end has different widths. It states the front end was widened another 1.6" for a total of 3.6" wider than the rear. Would this be the case on the earlier cars also?
I believe all A-bodies had wider front track than rear track -- the exact amount changed over the years. Apparently, by 1973 it had become noticeable to the average joe on the street, hence the bulletin.
