Fan blade on Dart broke today
Heating / Cooling / AC
  1. Mopar to ya
    Mopar to ya Well-Known Member
    3,033
    134
    May 17, 2011
    North Branch, Minnesota
    Local Time:
    11:23 AM
    I hauled my motor to my buddies shop today, so I have the motor and tranny there waiting to go into the Dart in a week and a half. The time was almost perfect. I could drop off my brother's truck, drive home, drop the Dart at my buddies shop and be there just in time for my wife to get off work and pick me up. Sweet! I was driving down the highway at 65 mph and I thought I had a flat tire. It was shaking badly. I pulled over and at idle it was shaking so violently I thought the dash was going to fall off. I shut it off, got out in rush hour traffic and popped the hood. The first thing I saw was the alternator belt was off. Then I see two blades from the fan lying on top of the power steering pump. How the hell does that happen? It was running very well considering it was only 40 degrees out.
  2. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    63,408
    53469
    Jan 18, 2006
    Iowa
    Local Time:
    11:23 AM
    How many blades? What diameter? Clutch? I may be able to help. tmm
    • Like Like x 1
    • dustermaniac
      dustermaniac Senior Member
      6,183
      550
      Oct 23, 2009
      Modesto, CA
      Local Time:
      11:23 AM
      Ouch!!! Lucky it didn't shoot through the radiator.
    • GEO
      GEO Sarcasm Inc.
      1,924
      235
      Feb 12, 2012
      Irvington ,Indiana
      Local Time:
      11:23 AM
      Looks to me like the bolts were loose or to long and bottomed out before they made contact
    • 70DartSedan
      70DartSedan Not Banned - just hiding
      373
      51
      Dec 18, 2011
      None
      Local Time:
      11:23 AM
      Maybe over torqued and the fan fatigued with the speed of rotating
    • bremereric
      bremereric Well-Known Member
      1,271
      22
      Dec 18, 2009
      Houston, Texas
      Local Time:
      11:23 AM
      Or the hood.
    • jimjimjimmy
      jimjimjimmy lobsterman FABO Gold Member
      4,747
      1604
      Nov 2, 2010
      p. e. i.
      Local Time:
      1:23 PM
      same here
    • Mopar to ya
      3,033
      134
      May 17, 2011
      Local Time:
      11:23 AM
      I have been driving it this way the entire time I have owned the car. You would think I would have felt a vibration at least. The rest of the fan is firmly bolted on. At 65 mph with my rear end I am just shy of 4000 rpm. I never heard a bang or clank or anything. It just started vibrating and I thought I had a flat. I was pissed because I finally bought a spare and a jack base for the car and they were both back in my garage! The radiator is fine, as you said, thank goodness. The hood appears fine as well, and I just painted top and bottom when I put the scoop on. Thank goodness, because the underneath part of the hood looks as perfect as the top.
    • Mopar to ya
      3,033
      134
      May 17, 2011
      Local Time:
      11:23 AM
      I would buy that. My rpm is high. It sucks because this motor comes out in 10 days and I wanted to reuse that fan blade.
    • inkjunkie
      inkjunkie Well-Known Member
      17,317
      2817
      May 24, 2009
      Local Time:
      9:23 AM
      Happened to me once, took out the radiator. Previous owner had put studs in the water pump and the unthreaded section was a bit to long......
    • Brad426
      Brad426 Well-Known Member
      495
      121
      Sep 13, 2010
      Ottawa, Ontario Canada
      Local Time:
      9:23 AM
      Yikes!
    • Bulldozer
      Bulldozer free ice cream sandwiches
      14,986
      2332
      Oct 16, 2011
      behind the wheel
      Local Time:
      11:23 AM
      i have never in all my days seen that happen. i chopped up a cat up once that was sleeping on my warm engine on a cold day, threw cat guts everywhere, scared the sh*t out of me, made a helluva racket
    • toolmanmike
      63,408
      53469
      Jan 18, 2006
      Iowa
      Local Time:
      11:23 AM
      I don't think the hub would turn if the bolts were bottomed out. The water pump hub is tapped all the way through. tmm
    • Mopar to ya
      3,033
      134
      May 17, 2011
      Local Time:
      11:23 AM
      Did that once too. Thank goodness I was parked next to a dumpster.
    • 412 Stroker
      412 Stroker Well-Known Member
      1,615
      31
      Jun 16, 2010
      Green Bay, WI
      Local Time:
      11:23 AM
      Boy I have a flex fan on mine now and I bought a 7 blade fan and thermo clutch, and now I am worried this might happen to me, did you have a shroud on?? and how many blades was it and did you have a thermo clutch or was it direct drive??
    • michformulaS
      michformulaS Well-Known Member
      813
      21
      May 14, 2005
      Midland Michigan
      Local Time:
      12:23 PM
      I had one blade turn 90 degrees into my raditator in my 70 340 duster years ago. I punched it and heard a terrible noise and steam. Opened the hood and there it was one blade bent 90 degrees into the rad. Weird and frustrating.
    • Mopar to ya
      3,033
      134
      May 17, 2011
      Local Time:
      11:23 AM
      Direct drive 7 blade flex fan with shroud. Missed the radiator and shroud and was laying on top of the power steering pump. I wanted to reuse this fan on the new motor because it kept the temp at or below 200 all summer long. It worked well.
    • pishta
      pishta I know I'm right....
      21,736
      11137
      Oct 13, 2004
      Tustin, CA
      Local Time:
      9:23 AM
      I got a thermo-clutched one if you need it. Off an 86 TRuck. Its huge though 20" , Ill put it in the sale section if you dont need it, PM me.
    • green1
      green1 Well-Known Member
      4,639
      21
      Dec 6, 2008
      Orange Park, Fla
      Local Time:
      11:23 AM
      A flex fan will cut/kill you to death. Can you take a pic of it, looking head to the break? Any signs of fatigue?
    • Mopar to ya
      3,033
      134
      May 17, 2011
      Local Time:
      11:23 AM
      The car is 40 miles away in my buddies shop right now. I won't get there until Saturday most likely. I'll take the rest off and inspect.
    • Oldmanmopar
      Oldmanmopar Going left turning right FABO Gold Member
      9,812
      6994
      Jan 8, 2009
      Danielsville Pa. 18038
      Local Time:
      12:23 PM
      If the car is not original and your not worried about having the original fan go electric. You'll never have that happen again. You'll also free up some ponies.
    • 1970Duster
      1970Duster Well-Known Member
      6,644
      93
      May 30, 2010
      Local Time:
      9:23 AM
      100% agreed on that! Also who made the fans and rad?
    • Oldmanmopar
      9,812
      6994
      Jan 8, 2009
      Local Time:
      12:23 PM
      B-cool rad and fans. Rad. was modified for AN fittings by my son.
    • Dartnut
      Dartnut Don't hate me because i'm beautiful
      11,875
      5013
      Apr 19, 2007
      Southern Alberta
      Local Time:
      10:23 AM
      I was thinking that the fan was slightly bent at one time, the water pump was bad, or the fan was just fatigued by constant high revs.....
      I'll bet your water pump is toast now too if it wasn't before.
      Yes, i agree that you were very lucky that it wasn't worse!
      Just thinking/typing out loud.........
    • Badart
      Badart Senior Member
      5,170
      89
      Feb 14, 2009
      Northern Utah
      Local Time:
      10:23 AM
      That sucks, but here is a story for you. I used to own an early 80's Jeep Grand Wagoneer. I was driving it down the highway one day and BOOM, RRRRR then steam everywhere. I pulled to the side of the road. Then a second later I see a ford van pull in front of me. I figured that they stopped to see if I needed help, so I popped my hood and my fan and water pump shaft were gone. I walked up to the van to see if I could get a ride and it was one of those handicapped vans and the lady inside said that she ran over and was dragging whatever I lost.
      I looked under the rear axle of her van and my fan was wedged between her rear axle housing and brake line and it was pouring brake fluid out of it. Well not only did I get to pay for the tow and brake line on her van I had to limp my Jeep to the nearest autozone and fix it in the parking lot. Not a good day. So you should feel lucky.
