willyj
I have a 66 Barracuda with a 273. No AC, little four blade fan.
Today while tinkering and hitting a standstill with the carb I pulled the fan and spacer as put on a five blade with an Eaton thermostatic clutch. Fit the pulley fine, bolts to the water pump fine. Was almost happy....
Till I spun it by hand and noticed the fan blades contact my upper radiator hose and neck. Not bad, but not enough I'm gonna run it.
So I ditched that and put on a five blade fixed fan from a 68 318 block I have. Still a little irritated though.
What are some factory clutch fan options that fit or is there a radiator that bolts in that puts the upper neck off to the side?
Would appreciate any input. The clutch fan I had was from a 88 318 from a Dodge truck. I also had a 7 blade from a 440 that fit the clutch!!! But it was the same diameter as the five blader.
