Fan clutch to radiator core distance?
rustytoolss
Clinton, Ohio
Like the title says Thermal fan clutch (front to radiator) distance to radiator core ? What's acceptable ? Normal ? I'm about 7/16" tad less.
Using the parts avail at the time,, my son's ended up less than a 1/4 in. away,, so we rigged a chain from the bellhousing to the trans cross-member,, so the fan can't contact the rad, if the car comes to an abrupt halt for some reason..
He's gone thru 2 summers without a shroud, never got near hot, stock copper rad.. if it helps..
If running a Shroud, The fan blades should be halfway in the shroud. Following this will always put you where you need to be.....
If no shroud, I would shoot for around 1/2 inch give or take...need wiggle room for things to shift around during hard Accel or hard braking....
