moparmat2000
Think cone shaped leading away from the radiator to the fan to lead the heat away, or a raised box off the back side of the radiator to lead into the electric fan, or engine driven fan. This allows space for the hot air to get away from the tubes and cooling fins.Maybe I'm a little dense, but I can't picture what you mean by "DO Not make the shroud flat-it needs to be off of the radiator and flow to the fan." Do you mean not to mount the shroud flat against the Radiator? I always thought it was best to mount the shroud flat against the Radiator to keep air from leaking past the shroud and to force all the air through the radiator.
