fan shroud won't fit
Heating / Cooling / AC
  1. cudajim
    cudajim cudajim
    1,425
    46
    Jan 17, 2006
    Grass Valley, Ca.
    Local Time:
    8:46 AM
    I have a 67 Barracuda with a 318 engine, factory radiator and shroud. The shroud fits the radiator just fine but the 7 blade fan hits it on the passenger side. It's way off by at least 1.5". It used to all fit when I had the 273 engine in there. I don't know what's off. I'm thinking possibly motor mounts are installed wrong but everything about the motor seems right. The exhaust fit correctly and everything is lined up as it should be. The reason I want the shroud is because the engine runs warm so I'd like to try it to see if it makes a difference. I don't know what else to check.
  2. moparmandan
    moparmandan FABO Gold Member FABO Gold Member
    2,527
    2350
    Jun 28, 2017
    Deland, FL
    Local Time:
    11:46 AM
    Shroud upside down? Wrong shroud, got mixed up somewhere? Just grasping.
    1.5" is a lot........
    Shroud should have a part number on it.
    • Agree Agree x 1
    • Mike69cuda
      Mike69cuda 64 is the new 17 FABO Gold Member
      1,820
      1346
      Jan 2, 2018
      Overland Park Kansas
      Local Time:
      10:46 AM
      Mopar shrouds are offset about exactly that much. The engines (on A bodies at least) sit about an 1 1/2 Inches off center to the passenger side.
      • Agree Agree x 1
      • cudajim
        cudajim cudajim
        1,425
        46
        Jan 17, 2006
        Grass Valley, Ca.
        Local Time:
        8:46 AM
        It can only mount one way, I tried it upside down... no way. Here's pics
      • Cuda Al
        Cuda Al Well-Known Member
        1,099
        1214
        Oct 21, 2007
        Lompoc, CA
        Local Time:
        8:46 AM
        What is the number on the shroud?
        What is the radiator number?
        Thanks,
        Alan
        • Agree Agree x 1
        • ch1ll
          ch1ll FABO Gold Member FABO Gold Member
          753
          259
          Jun 12, 2009
          Belgium,wi
          Local Time:
          10:46 AM
          Radiator mounted correctly?
        • cudajim
          cudajim cudajim
          1,425
          46
          Jan 17, 2006
          Grass Valley, Ca.
          Local Time:
          8:46 AM
          The shroud number is 2582037
        • cudajim
          cudajim cudajim
          1,425
          46
          Jan 17, 2006
          Grass Valley, Ca.
          Local Time:
          8:46 AM
          Yes, it only matches up to the 4 holes
          • Thanks! Thanks! x 1
          • Cuda Al
            1,099
            1214
            Oct 21, 2007
            Lompoc, CA
            Local Time:
            8:46 AM
            That is a /6 shroud, the V8 one is 2785312, people have been know to make the work mounting them upside down.
            Alan
            • Like Like x 3
            • Agree Agree x 1
            • cudajim
              cudajim cudajim
              1,425
              46
              Jan 17, 2006
              Grass Valley, Ca.
              Local Time:
              8:46 AM
              The radiator # is 38086
            • cudajim
              cudajim cudajim
              1,425
              46
              Jan 17, 2006
              Grass Valley, Ca.
              Local Time:
              8:46 AM
              Interesting. I had 2 shrouds too, probably sold the one that's right for the V8. I tried this one upside down, it does not fit
            • moparmandan
              2,527
              2350
              Jun 28, 2017
              Deland, FL
              Local Time:
              11:46 AM
              Zactly what I was thinking, lol.
            • krazykuda
              krazykuda Well-Known Member FABO Gold Member How-To Section Editor
              55,032
              20381
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              10:46 AM
              Restoration Radiator Fan Shrouds
            • Alaskan_TA
              Alaskan_TA Well-Known Member
              5,717
              4024
              Nov 12, 2004
              PA
              Local Time:
              11:46 AM
              The 5 digit number if it is an original radiator is the vendor ID for the vendor that supplied it to Chrysler.
              Look for a 7 digit part number.
            • Dana67Dart
              Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
              5,123
              3161
              Jul 16, 2017
              Northern Colorado
              Local Time:
              9:46 AM
              IMHO
              Don't add a shroud, fix the cooling issue.
              Pulley sizes, # water pump vains, radiator cores, radiator clean, block clean, thermostat proper temp, proper pressure cap etc.
            • 4spdragtop
              4spdragtop FABO Gold Member FABO Gold Member
              29,561
              9891
              Aug 28, 2009
              Wasting time here
              Local Time:
              10:46 AM
              Rad hoses still line up with rad?
            • Dana67Dart
              5,123
              3161
              Jul 16, 2017
              Northern Colorado
              Local Time:
              9:46 AM
              What you don't know is if the rad was recored in its life. If so (most likely) it might have been recored with a less efficient core.
            • kursplat
              kursplat FABO Gold Member FABO Gold Member
              3,446
              2309
              Aug 24, 2010
              so cal
              Local Time:
              8:46 AM
              centered = /6
              offset 1 1/2" = SB v8
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              19,179
              7078
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              10:46 AM
              What's "warm"?
              • Agree Agree x 1
              • kursplat
                3,446
                2309
                Aug 24, 2010
                so cal
                Local Time:
                8:46 AM
                no longer cold
                • Agree Agree x 2
                • Like Like x 1
                • krazykuda
                  55,032
                  20381
                  Aug 20, 2007
                  Orland Park, IL
                  Local Time:
                  10:46 AM
                  Shrouds are an important part of the cooling system...
                  • Agree Agree x 3
                  • BobW
                    BobW Curmudgeon At Large
                    178
                    92
                    Jun 26, 2020
                    Central, FL 34705
                    Local Time:
                    11:46 AM
                    Let me know if you want to sell the /6 shroud.
                  • lilfontleroy
                    lilfontleroy annoyinglilLeroy FABO Gold Member
                    2,685
                    2428
                    Nov 20, 2017
                    Intercourse
                    Local Time:
                    10:46 AM
                    does the buyer think they got a slanty shroud? if you know how to get in touch with him/her maybe a "correcting" trade is an option?
                    • Agree Agree x 1
                    • AJ/FormS
                      19,179
                      7078
                      Jan 19, 2014
                      Local Time:
                      10:46 AM
                      What I mean is; warm is relative.
                      Some guys think 160 or 180 is warm.
                      I run 205 or more as warm.
                      Warm is good. Warmer is better. It's all good until the oil gives up, or the coolant boils
                      The trick is to make sure the engine temperature is stable, whatever it is; and that 7-blade fan is a key player, for as long as the clutch on it continues to work properly. And at low speed,(below about 30mph),the shroud is the third member of the three-part team.
                      >The properly working thermostat sets the minimum coolant temp, and has nothing to do with the maximum, unless it is defective.
                      >The maximum coolant temp is governed by the efficiency of the system, and varies with both engine speed and roadspeed.
                      >Below about 30mph, the fan/shroud/clutch/coolant circulation, are the important players.
                      >Circulation consists of;the rad cores, the pump, the pulley ratio, the belt,the rpm,the stat, and the hoses including the bypass.
                      >Idle is the hardest to deal with, as the pump-speed is the slowest, and the air has to be "sucked" thru the rad. The faster the vehicle is moving the less work the fan has to do. Which is good, cuz the faster the engine is turning, the more heat it generates. Somewhere between 30 and about 45mph, the system is loafing. Depending on the operating rpm, after about 45mph, the system is gonna start generating heat again.
                      >To prove your system, you can remove the stat, take it apart, and put the washer part back in. This will cause the engine to be slow to warm up. But it will allow you to judge the capability of the rest of the system.
                      BTW;
                      The fan does not suck air thru the rad.
                      The fan IN THE SHROUD, creates a low pressure area on the engine side of the rad. The higher air pressure on the bumper side then wants to go there. But the rad is in the way. Anything you can do to make it easier for the air to muscle it's way thru the rad, is gonna increase the efficiency of your system. But at low roadspeed, everything depends on that shroud being there. Without it, the air being slung radially around by the fan just goes round the end of the blades and back to the front side. And around and round it goes. That fan you showed is about the best design out there, so you are on the right path. You just need to duct it....... with a shroud. Then you will be well on your way to solving your cooling problem.
                    • yellow rose
                      yellow rose Master Of Insanity
                      24,425
                      20424
                      Jun 19, 2015
                      Walking a crooked mile
                      Local Time:
                      8:46 AM
                      If you want to make power and/or control detonation hotter is bad.
