Farm Find...66'Valiant wagon
Slant 6 Engines
  1. tiltedsix
    tiltedsix Well-Known Member
    47
    21
    Jul 4, 2013
    seaside OR.
    Local Time:
    9:54 AM
    hello just picked up a 1966 PLY Valiant 100 Wagon..1 owner .they said it ran in 04'....put battery in it no power from key no lights,,,,,was going to get a new Ballast resistor, power relay module , what am I forgetting ?
  2. clifftt
    clifftt Well-Known Member
    2,034
    463
    Nov 13, 2007
    Concord, CA
    Local Time:
    9:54 AM
    Pics!
  3. omahamoparguy
    omahamoparguy Well-Known Member
    762
    20
    Feb 19, 2010
    Local Time:
    10:54 AM
    ground connections from battery to block. next in line would be the fusible link from battery. Cheap volt/ohm meter is good to have in these situations.
  4. limegreen70
    limegreen70 Pokorny Enterprise's
    1,353
    196
    Apr 27, 2014
    Milton PA
    Local Time:
    11:54 AM
    Pictures!! please.
  5. memike
    memike Super Moderator Staff Member FABO Gold Member
    48,914
    8940
    Jan 8, 2006
    on the hill
    Local Time:
    11:54 AM
    Ground from the battery to the block :glasses7: and I would add a ground from your battery to body as well, bulk head connections need to be looked at carefully and cleaned ....13 years is a long time with.
    Yep a volt meter is your best friend :coffee2:
  6. famous bob
    famous bob mopar misfit
    11,508
    2907
    Aug 14, 2011
    okla
    Local Time:
    11:54 AM
    don`t bother, load it on a truck, and send it to me w/ the title---lol--bob
  7. krazykuda
    krazykuda FABO Gold Member FABO Gold Member
    46,374
    11395
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:54 AM
    If it has no power from key to lights as you say, check the fuseable link. When there is no power or lights, that's usually the problem.
    also clean the battery connections like Mike stated above.
  8. tiltedsix
    47
    21
    Jul 4, 2013
    seaside OR.
    Local Time:
    9:54 AM
    so I re-placed the Ballast Resistor, Ignition relay , Power Relay, re-placed fuses in fuse box , can't find a fuse able link to battery...has electronic points ,caps good put new Spark plugs -gaped at 40....can Ark Jump start Starter and turns over stonge, put fresh gas in it but after 50-60 cranks not picking up gas to carb... still no power at dash or lights , also has a canister that's plumbed to water hoses that you can plug in '''' ..it works heats up quik......will keep looking for fuse able link....it doesn't have a 'condenser any were will get one tomorrow.....that's all it took on last car 72 Scamp
  9. pettybludart
    pettybludart Well-Known Member
    15,741
    109
    Jul 18, 2008
    Ontario,Canada
    Local Time:
    11:54 AM
    As mentioned...bulkhead connection.Check under dash to see if power coming in through the bulkhead.Seperate at firewall to check for corrosion..common problem.
    • Like Like x 1
    • halifaxhops
      halifaxhops It's going to get stupid around here! FABO Gold Member
      48,796
      16794
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      12:54 PM
      Nice find! I am sure you will find the problem.
      • Like Like x 1
      • kowalski440
        kowalski440 Well-Known Member
        179
        50
        Dec 20, 2014
        Milan In
        Local Time:
        12:54 PM
        Hate to be an english nazi but that's hard for me to read/comprehend. One big run on sentence.
      • Pete in NH
        Pete in NH Well-Known Member
        228
        20
        Aug 26, 2014
        Holdeness,NH
        Local Time:
        11:54 AM
        Hi,
        Go over to mymopar.com and download a wiring diagram for your car. That plus getting that voltmeter will allow you to intelligently track through the electrical system and find the problems. I don't quite understand what you mean by the car has electronic points and you are looking for condensers. Also, a car that has been sitting that long with gas in the tank is likely to be all varnished up and I wouldn't be surprised if the fuel pick up sock in the tank is a solid mass of goo. Once you get the ignition system producing spark you might want to try letting the fuel pump draw clean fuel from a can.
        I see what looks like an aftermarket electronic ignition system in your pictures but who knows if its getting power or if it's any good anymore.
        • Like Like x 2
        • Syleng1
          Syleng1 Karma is real and Life is short... FABO Gold Member
          870
          483
          Jul 5, 2005
          North Franklin, CT
          Local Time:
          12:54 PM
          I think I am in love! If you cant get her running... I'd be glad to drive to NH and pick her up. I might even give you a few bucks for her. LOL!
          Nice find. I'm jealous.
          Joe
        • dartnabout
          dartnabout FABO Gold Member FABO Gold Member
          10,081
          2621
          Aug 27, 2007
          Central PA
          Local Time:
          12:54 PM
          Still a long drive and in the wrong direction to Oregon.:glasses7:
        • AJ/FormS
          AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
          15,258
          4374
          Jan 19, 2014
          South-Central Manitoba,Canada, 900ftelevation
          Local Time:
          11:54 AM
          Can you meet me in South Dakota?
