faulty filler neck grommet?
Fuel and Air Systems
  1. phaelax
    phaelax Well-Known Member
    352
    101
    Sep 3, 2014
    Ohio
    Local Time:
    1:42 PM
    I replaced an old worn grommet to stop a mild gas leak a few months ago. Today while filling up at the gas station, it started dumping onto the ground once it neared the top. I looked underneath to see the brand new grommet had split in half!
    So now while I wait a week for a new one to come in the mail, I'd like to figure out how it split completely apart. Faulty product? Could I have done something wrong installing it?
  2. adriver
    adriver Blazing Apostle
    8,614
    5347
    Jun 1, 2007
    Where the red fern grows
    Local Time:
    1:42 PM
    It's very odd.
    I wouldn't think there is enough stress on it to cause any thing like that to happen.
    It's just a snug fit on the tube
    Even old age doesn't seem to make them fail.
    • Like Like x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      20,793
      8167
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      12:42 PM
      Defective, bad engineering, bad materials, or all.
    • phaelax
      352
      101
      Sep 3, 2014
      Ohio
      Local Time:
      1:42 PM
      $25 from jegs last time. Found one on ebay for $9 located in that state up north, so I should hopefully get it this week.
    • phaelax
      352
      101
      Sep 3, 2014
      Ohio
      Local Time:
      1:42 PM
    • JoesEdge
      JoesEdge Well-Known Member
      1,085
      253
      Jun 6, 2013
      Downey, CA
      Local Time:
      10:42 AM
      I'm having issues with my new grommet too. Filled the tank and it was spewing gas from the grommet. I may need a new one.
      Did you have issues getting the filler tube into the grommet? I had a had time getting into my new grommet. Maybe it got damaged then? Or maybe it was a crappy grommet.
      Anyway... I was wondering where you got your new grommet and how it worked out for you?
    • krazykuda
      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
      58,733
      24352
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      12:42 PM
      Where did you buy your grommets? What brand are they?
      Maybe there's some bad ones out there we need to know about...
    • barbee6043
      barbee6043 barbee 6043 FABO Gold Member
      14,070
      6810
      Jul 20, 2008
      Shepherd, Texas ( SE Tx)
      Local Time:
      12:42 PM
      probably CRAP chineese stuff, but, I always sand down the outside of filler neck to make sure it is smooth and the neck will slid into it without a big struggle. also lube the neck and inside of grommet with something like liquid spray silicone or baby oil / .
    • JoesEdge
      1,085
      253
      Jun 6, 2013
      Downey, CA
      Local Time:
      10:42 AM
      I bought it at Classic Industries right over the counter, and I think the brand was OER.
      On the website, they have two listed.
      MF296 - 1964-74 Mopar Fuel Tank To Filler Neck Grommet
      MF297 - 1970-75 Mopar Fuel Tank To Filler Neck Grommet
      I purchased the MF296 grommet for my '74 Duster. Factory fuel tank.
      Don't get any ideas, but I did lube it with petroleum jelly. LOL I didn't do any sanding though. I didn't even think of that. The new rubber grommet was kinda hard, just like the 40 year old rubber grommet that I replaced. I thought it would be softer.
    • TrailBeast
      TrailBeast AKA Mopars4us on Youtube
      21,682
      9490
      Mar 11, 2011
      Arizona
      Local Time:
      10:42 AM
      Looks like a lack of installation lube and the resistance tore it to me.
    • tnts72
      tnts72 Well-Known Member
      661
      31
      Jun 18, 2015
      Illinois
      Local Time:
      12:42 PM
      Gotta lube the fill tube and inside of the grommet. I used some wheel bearing grease.
    • JoesEdge
      1,085
      253
      Jun 6, 2013
      Downey, CA
      Local Time:
      10:42 AM
      Ok, then I guess I should pull the tube out and inspect it to see if it tore. I'll put that on my task list.
      Today I hope to pull the steering column out. I want to paint it black and also re-key the ignition cylinder. It's always something.
    • jdsduster
      jdsduster Well-Known Member
      1,199
      191
      Aug 5, 2011
      indiana
      Local Time:
      1:42 PM
      me too.
    • JoesEdge
      1,085
      253
      Jun 6, 2013
      Downey, CA
      Local Time:
      10:42 AM
      By the way, here's some pictures. I wonder if this is what the OP's grommet looked like when it was leaking.
      That wet area on the lip of the gas tank is fuel. You can see the shine around the filler tube where it "seals" against the grommet, I think that's gas too.
    • Hyperballsmcgee
      Hyperballsmcgee Well-Known Member
      229
      3
      May 5, 2013
      Murfreesboro, TN
      Local Time:
      12:42 PM
      I had a brand spankin new one that came with new tank fail on my valiant with no visual signs of damage. I live close to whitepunkonnitro and he gave me one off of a parts car, and that solved it. funny how a 40+ year old reused seal worked better than a brand new one.
    • AJ/FormS
      20,793
      8167
      Jan 19, 2014
      Local Time:
      12:42 PM
      Several years ago(many), I installed a brand new tank on my 80 Volare. It came with a new grommet. I could tell right off it was a bad fit and a wrong compound. It went straight into the trashcan. I reused that 1980 grommet, and it still works to this day,as it did, some 35 years ago. You can tell the junk by it's lack of lead-in chamfer,it's hardness/softness, and it's fitment.
    • phaelax
      352
      101
      Sep 3, 2014
      Ohio
      Local Time:
      1:42 PM
      The cheap one I bought on ebay has worked just fine. Designed differently than the jegs model. I installed it the same way, greasin it up with some oil. Still took a little force but slid in much easier than the first. I think the other one was the wrong size (too small inner diameter) and busted when I shoved the big tube into the rubber.
    • JoesEdge
      1,085
      253
      Jun 6, 2013
      Downey, CA
      Local Time:
      10:42 AM
      Hahahaha....yep, happens to me too!!
      After I tackle the interior, going to pull the grommet off and see what happened.
    • elvaliant66
      elvaliant66 Well-Known Member
      269
      16
      May 13, 2011
      EL MONTE ,CA
      Local Time:
      12:42 PM
      Going through the same crap can't get the tank with the grommet to slide into the filler neck. I bought the same part from classic industries and it does seem a bit smaller in diameter compared to the original. Too bad the original one tore in half when I pulled it off or else I would of just used that one . It seemed to slide in way easier. I'll try again tomorrow this time with some lube for easy slip in hopefully lol
    • JoesEdge
      1,085
      253
      Jun 6, 2013
      Downey, CA
      Local Time:
      10:42 AM
      Good luck! I haven't messed with mine yet. I think I might order another grommet else where and try my luck that way. Let me know how it goes!
    • mguner
      mguner How many is too many?
      5,129
      364
      Nov 26, 2006
      Amarillo,TX
      Local Time:
      12:42 PM
      The silicon lube they sell for pulling wire thru conduit is great for this....
    • threewood
      threewood Well-Known Member
      409
      243
      Nov 11, 2014
      Yuma
      Local Time:
      11:42 AM
      When you get your replacement, make sure your tank straps are tight. I could see some fore aft movement on the tank causing premature failure.
      I just replaced one that was split down the seam with one from Fillernecksupply.com and it was a perfect fit. Cleaned the neck area up and lubed with vasoline. No more fuel smell in my garage!
