Airborne_Tanker
so just a guess - since your oil light flickers (I'll bet it does it at idle in gear ) it may just be that the idle speed is too low. Once you bump it up it might be easier to start.
Regarding
do not let this go!!! I can still remember passing a car on a 2 lane road, having the damned bypass hose blow off, shoot anti freeze through the radiator out the front where it sprayed up and all over the windshield at 60 mph and blinded me. (year was 1978 and yes I'm still driving the car but only through pure luck).
Fixed the Bypass hose so were good there haha.
The dummy light does it at idle once warmed up and will flicker once or twice then stop put it in drive or anything and the RPMs drop the light doesnt come on. Im thinking its either a loose connection or sensor is going bad. Im installed actual pressure guage and all this week in it.
It starts alot faster now that i changed the Black ignition box to an Orange one but still a little slow. Still have to check the rotor and all in the distributor. Compression was great across the board, fuel is good, and plugs is good. Im thinking it may just be a weak starter. Ordering the Dakota mini starter tonight.
