YR and nm9stheham, if understood correctly the flat protrudes approximately .032 above the deck, this was with my caliper, I overlooked the part of the feeler gauge, going to recheck and confirm
And here I was thinking they weren't all that large compared to the 5 CC notches of something like a KB or Icon. I'd be guessing +5-6 cc's net, with the domes milled as they are, plus notches combined, referenced to the CH.I think you need the Sped Pro catalog to find the CC's of the dome. I may have that here. I'll look in a bit.
I do know that if you aren't at least .020 out of the deck the dome is either zero or may even be a minus number, IIRC.
One thing on those Pistons is the damn valve notches are HUGE. Especially for the exhaust valve. Just freaking gigantic. Total waste of CR.
ok, some readings I feel better about using the feeler gauge, if readings are off it would only be in the hundred thousands.
flat @ top of piston - .029 above deck
dome .184 above deck
head - shallow side - .083 deep
the .029 is above deck
the dome volume is what I was missing for the online calculators found on the net, using this one https://butlerperformance.com/n-12872-compression-calculator.html with a 10cc volume for the dome the noted SCR moves from 10.31 to 11.07, changing from a 68cc to a 72 cc for the head and using felpro's range of .049 to .059 for compressed gasket thickness.
Values I used:
bore dia. 4.030 (based on piston size)
stroke - 3.58 (stock)
cylinder head volume - 68 up to 72 (I read somewhere these were what had been seen in the past)
Dome volume -10cc
Deck clearance - .029 (I assume the measurement I took at the flat is this number)
Compressed gasket - .049 to .059
number of cylinders - 8
I concur that the current Lunati cam isn't the best for the rest of the engine, sucky part is what happens for the cam change another 400ish up close to 1000 depending on how it goes.
hydraulic or solid?
verify pushrod length - I now have a set for a solid and a hydraulic, no certainty either set will work.
replace springs - I don't know what the ones are in the heads and have no way to verify
upgrade/change torque convertor
total cost to change - cam, lifters, springs (plus gaskets etc.) probably around 400ish (based roughly on the cam Rusty linked to @ Summit)
pushrods if needed - 40.00 to 150?
torque convertor - 400ish maybe?
so a couple of things I know for sure (because this is what I have LOL)
engine will get a set of Dougs 453s Headers
gears will be 3.55s in a 8 1/4
intake will be Edelbrock RPM Air Gap
Carb - Holley 670 elect choke vac secondary's. (I have a Quickfuel Slayer 600 cfm) I think the holley will be a good fit, it ran well on my 351 in my Mustang before I swapped to fuel injection
Obviously with the engine torn down to where it is it would be better to swap cams now rather then later, I'm gonna continue some of the other work while I ponder this some more, perhaps if I have some luck here soon with a sale of a few spare parts I have it will help with the pondering LOL
Thanks for all the reply's and attempt to further my knowledge,
YR, I had mech and vac. secondary's, Edelbrock and Holley in the past, also some Rochester quadrajets many years ago, this Holley I have now has been the best carb I have ever owned, I have the available jets, springs, etc. to tune, it is adjustable on all 4 corners and has the billet base and metering blocks,
I think a 750 would be better suited for this car, especially if I up the cam, another 600.00 plus though and I have also thought about it (770 version of what I havehttps://www.summitracing.com/parts/hly-0-86770bl )
Anybody looking to sponsor a new Mopar owner in the pacific Northwest? I will put your name in bold 1/4" letters on the bottom quarter of the car as appreciation! LOL
Yes, use the measurement at the flat for the deck clearance. BTW, using your calculator, I get 11.6 for a 6 cc net dome volume, .029" above deck, .050" head gasket, and 72 cc head chamber. Both the deck clearance and dome volume should be entered as negative numbers in your calculator. And realize your domes have been milled a bit so the 10 cc net dome volume is too much IMHO. And head is probably more like the 68 cc number so now you're pushing over 12:1.the .029 is above deck
Values I used:
Dome volume -10cc
Im gonna go with the thought that I am at least at a 11.1.1 on the CR, at this point it will be the best path, I don't think getting the setup to do the fluid check will change the inevitable, motor needs a different cam,
on a good note I learned some more things about cams and CR and know more about the engine in my car, still sucks more money is going to have to leave my friendly bank account LOL
Is Brier on the west side or east side?? Yes, I'm being lazy...don't feel like digging out my atlas!! Yes, I'm THAT lazy...just ask my wife.
brier is just south of Everett between the 5 and 405 split
Really?? I used to drive that route all the time and I don't remember that.
Damn, I'm getting old. That's terrible I've either never noticed that, or I just don't remember that place. Dang.
Great idea, but only a handful of E85 stations in the whole sate of WA.E-85
Hey wyrm... did you end up having a catalog listing for these pistons?quit looking at cams till you know your compression
