yellow rose
Overnight Sensation
at this point not sure Im going to know anything more than I do now
this is the cam I took out of the car when I got it, solid lifter cam
So it's a Comp 292 solid?
I do have old trw and SP catalogs but we sold our house we had since 1955 and moved in december- everythings in boxes I did find a box of Mopar shop manuals and DC engine/ chassis etc booksHey wyrm... did you end up having a catalog listing for these pistons?
Hey YR....4007042. Check out the OP's pix in post #22 & #23; the fire notch is almost all milled off.
I am not sure, there are a few other letters on it but nothing that would show up in a google search
IF it's the Comp 292S, that's probably "enough" cam to do it.
it may just find its way back in the motor so I can be done with it, at least no break-in needed.
after some setback and delays went ahead and did some checks, I originally found a thread on here with cylinder info volume but can't find it now. - here's where things ended up, with online calculators I come up with around 10.8 on static and 8.4 on dynamic. Curious where this engine will end up with the 292 cam with 247/254 duration and 508 lift performance wise now
info and details:
TRW 11.5.1 dome pistons, unsure if they were milled as has been referenced based on cc value and what I have read on here Im gonna say yes
X-heads - measured volume 68.5 ( this was average - none at 68 and none at 69)
piston 1" down - 205cc's - (+/- about 1 cc)
stroke - stock
Bore - 4.030
Head gasket bore 4.180
head gasket thickness - specs say .049 - .054 - I measure the inner rind and got .054
deck clearance - .01 - this is a bit of a guess but I just don't know and with two different sets of heads everything still aligns well
IVC @ 50 with the cam degreed in @ 106.5 centerline.
Thanks, seems like some of you guy's have better math skills than the online calculators, Im guessing it should put out at least 400ish HP, should get the Dart moving, still will need to address the convertor and transmission later on but right now just trying to get it all back together.
Was the 1" down actually 1.000" or very close? And was it with the piston moved 1.000" down from the TDC position, or with the flat area moved 1.000" from the deck? Just shooting for best accuracy.
If so, I get a net dome volume of +4 cc at an effective deck height of 0.000" per your 1" down measurement (as I first interpreted what you did). The pure cylindrical volume with no net dome or eyebrow works out to 209.0 cc for a 4.030" cylinder.
With that, plus a compressed head gasket thickness of .051", 3.58" stroke, 4.03" bore, 4.18" gasket hole, and an added 1 cc for the crevice, I get 10.75 static CR.
If you moved the flat of the piston down 1.000" from the deck (.990" actual movement from TDC), then I get 10.46 SCR.
For DCR, the IVC at the .050" lift angle is not what is used. The IVC angle is put in as either the advertised duration IVC, or an IVC based on the .050" lift plus a number like 15 to 20 degrees. (Comp's method IIRC). Using the 292 advertised, an LSA of 110 and an ICL of 106.5, I get a DCR of 7.9. If I use the .050" IVC + 15 degrees, I get a DCR of 8.31. So that brackets your DCR range.
I have not bothered to work it out at any elevation as you look to be near sea leve.
As i mentioned I saw somewhere on this site that had the cylinder volume, and as mentioned at 1" it was 209cc's, I figured the 4 cc dome, using the calculator below with straight numbers it appears fairly close, curious if the HP calculator on same website is reasonably close to. At least one thing, detonation shouldn't be to hard to avoid. Pretty funny that of the several calculators that technically should be the same end up close - but not exactly even when the same data is used. I did read somewhere about adding to the IVC but no where did I find that in the calculators - thanks for the replies and info - optimistically the engine runs out well and at least manageable on the street, and of course able to do a burnout.
The Free & Accurate Horsepower Calculator
I just ran my numbers through there and it shows mine making at least 50 HP more than it will. I’m pretty sure.
