Firing order
Slant 6 Engines
  1. Brian Bearor
    Brian Bearor Well-Known Member
    48
    4
    May 1, 2021
    New York
    Local Time:
    6:17 PM
    Just purchased a 63 Valiant with a 225. It has been sitting for a bit and running rough. Completed a tune up and the firing order was not to spec. Use the firing order below now will not run. Is it incorrect? FB_IMG_1619875304799.jpg What am I missing? Thank you for all suggestions.
    • Thanks! Thanks! x 1
    • Dana67Dart
      Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
      8,298
      5815
      Jul 16, 2017
      Northern Colorado
      Local Time:
      4:17 PM
      The dist might have been installed out of phase with the crank.
      As in the rotor might be pointing at a different post on the cap when the engine is at TDC of the compression stroke on the number 1 cyl.
      • Badvert65
        Badvert65 Long Time Mopar Nut
        369
        161
        Sep 21, 2014
        Brightwood, VA
        Local Time:
        6:17 PM
        That is the correct firing order, but..
        Make certain that the rotor (inside the cap) is pointing to the wire for #1 plug with the rngine at #1 TDC.
        • Like Like x 1
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          81,556
          61207
          Jun 7, 2010
          Georgia
          Local Time:
          6:17 PM
          The firing order and direction of rotation is correct in the picture. What's not correct is WHERE the wires go in the cap. #1 should be where #4 is in the picture, if the distributor is still installed correctly. I agree with pulling #1 plug, get it up on the compression stroke, line the marks up on zero and see where the rotor is pointing.
          • Agree Agree x 2
          • Like Like x 1
          • tonysrt
            tonysrt FABO Gold Member FABO Gold Member
            1,009
            526
            Dec 25, 2016
            Northport, NY
            Local Time:
            6:17 PM
            That's correct firing order and distributor rotation. Check the points to make sure they're opening and they aren't pitted. Then check voltage at the coil when key is in run position and in start position. Or just crank to see if you get spark while cranking with a shorted spark plug wire. A voltmeter would make this job a little easier. If you are really new to this game maybe seek someone with some more knowledge.
            • Like Like x 1
            • 67Dart273
              67Dart273 FABO Gold Member FABO Gold Member
              52,492
              21646
              Oct 14, 2010
              Idaho
              Local Time:
              3:17 PM
              Ok some "stuff." Some "rambling..........
              First, the main reason on most cars that firing order/ wire location is specified is so that
              Cut factory wires will "lay" right
              The assembly line folks can "rinse, repeat"
              And tune up guys "see what they expect"
              There might be a fair reason NOT to change a working but so called incorrect wire position, especially on a slant. That's because..........
              The dist gear is plastic and can be easily broke with screwin' round
              The dist movement is limited, without moving the bracket clamp position using both clamp bolts........one on the block, and one under the dist.
              HOW TO check/ set timing
              Assuming you don't think the balancer ring has slipped--and there is a way to check that too.........pull the no 1 plug and devise a way to feel for compression. If you can't reach (on a slant) with your finger into the no1 hole, stick your compression gage hose in there or whatever. "Bump" the engine round until you feel compression starting to "come on." Now watch for the timing marks, and carefully stop the engine WHERE YOU WANT initial timing to be, such as 5 BTDC. Now look at the dist. With points, you want to adjust the dist from a retarded position towards advanced until the points just open
              With an electronic "rough" set the dist so the reluctor is in the middle of the pickup coil Look where the rotor is located, install/ remove the cap a couple times and identify which tower the rotor is approaching. THIS IS YOUR no1 tower. You can also install the cap and check timing "on the starter." Put it together and start the engine
              • Like Like x 1
              • 67Dart273
                52,492
                21646
                Oct 14, 2010
                Idaho
                Local Time:
                3:17 PM
                My first car was a 57 Chev 265 Hell for a long time I didn't know there WAS a "correct" no1 wire position. This was 66-68, when you pulled into a service station and actually got "service." One day one of the jocks told me, "that thing can't run, the timing is off. The wires are all wrong". Drove in it!!!! Drove it out!!!
                • Like Like x 1
                • pishta
                  pishta I know I'm right....
                  21,828
                  11256
                  Oct 13, 2004
                  Tustin, CA
                  Local Time:
                  3:17 PM
                  IIRC all straight sixes are the same firing order...153624. Someone told me think of your fat girlfriend from 4th grade's measurements....! Doesnt matter where the wires are, as long as #1 lines up.
                • RustyRatRod
                  81,556
                  61207
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  6:17 PM
                  Well.....it does matter if he took the wires off and they were on RIGHT, verses that WRONG diagram he's using.
                  • Agree Agree x 1
                  • Seon
                    Seon Well-Known Member
                    57
                    81
                    Apr 20, 2021
                    Lake Camanche, CA
                    Local Time:
                    3:17 PM
                    I've read on several post to place a finger over the #1 cylinder hole to check TDC. I always wad up a piece of paper then bump the starter. Once the wad "pops" out then that's TDC. Works for me that way.
                    • Like Like x 1
                    • memike
                      memike Super Moderator Staff Member FABO Gold Member
                      49,322
                      15565
                      Jan 8, 2006
                      on the hill
                      Local Time:
                      5:17 PM
                      I would hate to have the paper or what ever get sucked in ..
                      • Like Like x 1
                      • Agree Agree x 1
                      • KosmicKuda
                        KosmicKuda FABO Gold Member FABO Gold Member
                        2,261
                        994
                        Jan 15, 2011
                        N Ohio
                        Local Time:
                        6:17 PM
                        Picture from FSM. His hand is on #1 with #5 to the left of that. Note location of vacuum advance can and cap retention springs.
                        As already stated, if rotor tip is under #1 tower cap at TDC on compression stroke, it should start. A timing light will fire even while cranking.
                      • Seon
                        57
                        81
                        Apr 20, 2021
                        Lake Camanche, CA
                        Local Time:
                        3:17 PM
                        The wad is shaped like a spit ball and is much larger than the plug hole. Been doing that since the '60's taught to me by an old gear head. But any rate, thought I'd share what worked for me.
                        • Like Like x 1
                        • Brian Bearor
                          48
                          4
                          May 1, 2021
                          New York
                          Local Time:
                          6:17 PM
                          Thank you all for the suggestions. I followed the instructions and it runs much better than before the tune up. 1 was at 11 o'clock and I had it at 6 o'clock.
                        • memike
                          49,322
                          15565
                          Jan 8, 2006
                          on the hill
                          Local Time:
                          5:17 PM
                          thank you for clearing that up, I will do that next time sir :thumbsup:
