First Drive after building, Major shake
Transmission and Drivetrain Tech
  1. Calipag
    Calipag FABO Gold Member FABO Gold Member
    345
    129
    Apr 11, 2018
    Corona California
    Local Time:
    3:31 AM
    WELL! I was on my way home with the Dart. This is the first long drive since we built her and had her aligned. The build consisted of, swapping the drive line and rear from a 74 Dart. Changing our 1970 from a /6 manual drum car, 7 1/4 rear SBP to a V8, power disc, 8 1/4 BBP car. I used all the factory items from the donor car engine, trans, driveshaft and rear.
    The engine is a fresh rebuild, I just serviced the trans (new filter and fluid) and rear prior to installation. It has all new tires, and a new factory rubber front end part with a fresh alignment. I replaced both front caliber and brakes and rear brakes and 1 wheel cylinder on the passenger side.
    The car drove great on the side streets, alignment was great and the car was running well.
    Then I jump on the freeway and get up to 50-55 and everything is good for a while then I get this terrible vibration through the whole car. It shook as if I had a flat, and I actually thought I may be losing the driveshaft. I pulled off the freeway to the nearest parking lot and checked over the car. Everything seemed the way it should be. I convinced myself that it was the road and started on my way again. The car ran fine, steering fine everything seemed good. After driving for awhile it did it again. I pulled to the shoulder and waited and then continued on. I got off the freeway and took side streets home the rest of the way. The car seemed fine on the side street even after getting up to 45-50.
  2. valiantwagonguy
    valiantwagonguy Well-Known Member
    923
    622
    Oct 20, 2005
    Long Island
    Local Time:
    6:31 AM
    It could be a brake problem where a wheel is heating up or the universals
    • Thanks! Thanks! x 1
    • Mr. Sinister
      Mr. Sinister Devastation Manager FABO Gold Member
      1,197
      691
      Mar 3, 2017
      Lenox, Mich.
      Local Time:
      5:31 AM
      New trans mount?
    • Calipag
      345
      129
      Apr 11, 2018
      Corona California
      Local Time:
      3:31 AM
      Universals feel tight.
      I was thinking brakes, also but why only at speed- sometimes?
    • Calipag
      345
      129
      Apr 11, 2018
      Corona California
      Local Time:
      3:31 AM
      I did not replace the trans mount but there is no thump on the floor when I go from D to R. I was taught that was a tell of a bad trans mount.
    • Mr. Sinister
      1,197
      691
      Mar 3, 2017
      Lenox, Mich.
      Local Time:
      5:31 AM
      Bolts tight? Trying to help not hinder.
      • Agree Agree x 1
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        45,658
        13395
        Oct 14, 2010
        Idaho
        Local Time:
        3:31 AM
        This is VERY disturbing. Vibrations usually are not intermittent. That is usually they come on at certain speeds, certain gears, certain engine RPM. This might be something, loose wheel, improper wheel fit to hub (such as wheel with too small center bore not centering properly on hub) I don't know. Something loose, allowing a "shimmy" situation
        I WOULD NOT DRIVE this until you can do an in -depth look at things. Try different wheels/ tires a pair at a time.
        • Agree Agree x 2
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          16,253
          16022
          Jul 22, 2017
          Manitoba
          Local Time:
          5:31 AM
          Brakes. Had a ranger do it last fall. Owner used the parking brake and it hung up. Causing a drum to go out of round when it got hot. It did get very hot.
        • MoparMike1974
          MoparMike1974 FABO Gold Member FABO Gold Member
          2,745
          1980
          Jun 16, 2017
          Maryland
          Local Time:
          6:31 AM
          My vote is brakes also.
          • Blind Squirrel
            Blind Squirrel Well-Known Member
            846
            670
            Oct 1, 2015
            Pacific NW
            Local Time:
            5:31 AM
            Did you redo the front wheel bearing sets? It could be wheel bearings. If you set them to tight. Once everything heats up and starts expanding they start grabbing at the races.
            And check your lug nut torque.
            • Dana67Dart
              Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
              5,298
              3313
              Jul 16, 2017
              Northern Colorado
              Local Time:
              4:31 AM
              My vote is out of balance tire and /or bad shock .
              1. Out of balance tire, slow enough the out of balance is not sufficient to produce vibration. Fast enough and things get to bouncing.
              2. Bad shock, at speed everything is fine til the tire hits a large enough bump to get it to bouncing and hits its harmonic frequency and amplifies.
              3. Alignment off, yes it was just done but it might not be right. My 67 dart has a shimmy at 40 to 45 everything is in acceptable shape but I'm sure the alignment is off. Above or below the speed and it drives great, no pull good road feel.
              • Dana67Dart
                5,298
                3313
                Jul 16, 2017
                Northern Colorado
                Local Time:
                4:31 AM
                Another thought.. do you know the other car drive train didn't do this too?
              • RustyRatRod
                RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                65,845
                39169
                Jun 7, 2010
                Georgia
                Local Time:
                6:31 AM
                Bad tires sometimes do this when they begin to separate.
                • Agree Agree x 2
                • Like Like x 1
                • MrJLR
                  MrJLR Built, not bought FABO Gold Member
                  5,080
                  5238
                  May 14, 2015
                  Chino, California
                  Local Time:
                  3:31 AM
                  Wheel ballance?
                  Jeff
                  • CCHHAARRGGER!
                    CCHHAARRGGER! Well-Known Member
                    129
                    70
                    Dec 5, 2017
                    california
                    Local Time:
                    5:31 AM
                    If its not the tires , the only other thing it could be is a bent drive shaft. I had a similar vibration only at highway speeds . The rear view mirror was useless because it was vibrating so much. It took a wile to figure it out. My Driveshaft came from a 70 duster in a junkyard . I took it and installed on my barracuda without getting it re balanced or checked out. I finally had enough took it out to bring to the drive line shop so they can measure the correct length for a new shaft. The tech takes my old driveshaft , rolled it on the ground . Then we saw the beg bend in the tube. Problem solved
                    • jboyd2
                      jboyd2 68 cuda
                      240
                      18
                      Apr 21, 2015
                      Arkansas
                      Local Time:
                      5:31 AM
                      Checked the u joints and transmission mount?
                      • Agree Agree x 1
                      • inertia
                        inertia Well-Known Member
                        3,351
                        610
                        Feb 4, 2011
                        Victoria B.C. Canada
                        Local Time:
                        3:31 AM
                        Not enuff + Caster, causing "shopping cart" wheel shimmy.
                        Prob set to factory specs. for bias tires.
                        Check the alignment setting from the alignment shop, if the caster is near "0", or negative -
                        Try having the alignment set to attached chart for radial tires.
                        Bad tire/balance, with bad shock is viable, - brakes - not so much.
                        • Agree Agree x 1
                        • Calipag
                          345
                          129
                          Apr 11, 2018
                          Corona California
                          Local Time:
                          3:31 AM
                          Yes, tires are new and have been balanced.
                          • Like Like x 1
                          • Calipag
                            345
                            129
                            Apr 11, 2018
                            Corona California
                            Local Time:
                            3:31 AM
                            New Tires and balanced
                          • Calipag
                            345
                            129
                            Apr 11, 2018
                            Corona California
                            Local Time:
                            3:31 AM
                            I do not.
                          • Calipag
                            345
                            129
                            Apr 11, 2018
                            Corona California
                            Local Time:
                            3:31 AM
                            Brand new tires with balance and new shocks all the way around. The rear springs are the only items not replaced. I did use the original factory torsion bars.
                            The alignment guy that I took it to is a area expert for classic and custom cars.
                          • Calipag
                            345
                            129
                            Apr 11, 2018
                            Corona California
                            Local Time:
                            3:31 AM
                            This is something I'm going to check. I did have all of that apart and didn't thing of the front bearings.
                          • MrJLR
                            5,080
                            5238
                            May 14, 2015
                            Chino, California
                            Local Time:
                            3:31 AM
                            Sometimes a weight can come off....costs nothing to take a peek....
                            Jeff
                            • Agree Agree x 2
                            • plumkrazee70
                              plumkrazee70 Well-Known Member
                              2,657
                              746
                              May 5, 2013
                              Medford, Oregon
                              Local Time:
                              5:31 AM
                              He may be an expert, but what are the alignment specs? Did he give you a print out?
                              • Cuda Al
                                Cuda Al Well-Known Member
                                1,116
                                1226
                                Oct 21, 2007
                                Lompoc, CA
                                Local Time:
                                3:31 AM
                                Driveshaft out of balance?
                                Alan
