First start up of 572
Big Block A body Tech
  1. Crazy4408pac
    Crazy4408pac N. Michigan
    312
    3
    Jan 3, 2010
    Traverse City Michigan
    Local Time:
    10:41 PM
    This is the first start up after breaking in the cam. I did notice the pass side header studs need to be re-torqued. Also that I best get to tuning the carbs, as it appears to be running way rich.. The Cherry bomb extremes sound pretty good.
    https://vimeo.com/113652436
  2. scooby67
    scooby67 Well-Known Member
    374
    30
    Sep 4, 2011
    CT
    Local Time:
    10:41 PM
    Make sure you adjust your rear view mirror before backing out.
  3. FJ5
    FJ5 Well-Known Member
    1,191
    49
    Feb 14, 2013
    chickasha, Ok
    Local Time:
    9:41 PM
    Sounds pretty good. Can't wait to start mine one day. I gave myself of a goal to have it started before christmas.
  4. WRB426
    WRB426 Insane 4 Mopars FABO Gold Member
    2,237
    172
    Apr 20, 2011
    MA
    Local Time:
    10:41 PM
    Sounds good. Have fun melting tires.
  5. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    Noticed that huh? LOL
  6. bOb shingler
    bOb shingler Well-Known Member
    3,253
    153
    Jun 8, 2007
    warrenton, north carolina
    Local Time:
    10:41 PM
    nice hotrod but you have some garage cleaning to do this spring.
  7. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    Got that right. Been working on the Dart for 2 1/2 years. So have tools and parts, everywhere. Just bought a propane heater, so I can get out there and start putting stuff where it belongs.
    When I pushed it out of the garage(no brakes, yet. need bleeding), I thought, " Holy crap! this place is a mess!"
  8. 604B1duster
    604B1duster Well-Known Member
    953
    298
    Dec 30, 2007
    Local Time:
    9:41 PM
    sounds great :burnout:, is that paint on rear bumper ?
  9. racerhog
    racerhog RacerHog likes his Mopars
    1,047
    291
    Nov 18, 2008
    Monrovia SO-CAL
    Local Time:
    7:41 PM
    Looking Good...Sounds great... :)
    Cant wait for the test drive.... :)
  10. Sedanman
    Sedanman 67-9 Valiant specialist FABO Gold Member
    8,342
    517
    Apr 3, 2009
    chicago Il
    Local Time:
    9:41 PM
    It purrs like a kitten on steroids
  11. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    No. The guy I got it from had a Dodge ram sticker on it. I'll buff it out in the Sring.
  12. 67 Power Wagon
    67 Power Wagon Hemi Pawr or BUST!
    2,525
    87
    Jan 13, 2014
    Hell, USA
    Local Time:
    9:41 PM
    GAWD that sounds BAD ASS!
    NICE work!
  13. charger426
    charger426 Well-Known Member
    757
    17
    May 5, 2014
    MoparLand
    Local Time:
    10:41 PM
    Is that the edelbrock duel quad set up?
  14. moparlover
    moparlover Well-Known Member
    2,634
    22
    Dec 17, 2011
    hagerstown, md
    Local Time:
    10:41 PM
    yeah buddy!
  15. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    Yes
  16. charger426
    757
    17
    May 5, 2014
    MoparLand
    Local Time:
    10:41 PM
    How do you like it so far? Are you using a progressive linkage between the carbs or are they one to one?
  17. charger426
    757
    17
    May 5, 2014
    MoparLand
    Local Time:
    10:41 PM
    Oh and if I could add another question what are you doing about a hood? I'm hoping to keep my stock stock hood but I'm not opposed to a hinged Six Pack hood.
  18. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    One to one
  19. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    A bud has an extra 72 hood. I'm going to cut an oval hole 3/4" around the breather.
  20. charger426
    757
    17
    May 5, 2014
    MoparLand
    Local Time:
    10:41 PM
    Cool deal. I a couple of years away from doing the engine work on my dart but your intake set up is what I'm leaning towards. I think I'm going to go with a 512 through, want to be able to drive this everyday if I needed/wanted to.
    Do you any threads on your motor/car build?
  21. TOP
    TOP Well-Known Member
    271
    35
    Oct 23, 2008
    Boyertown PA. Near 19472
    Local Time:
    10:41 PM
    I have a 440 pretty much stock 68 motor in mine, and my garage is probably worse. Been trying to neat up for years .67 Dart convertible,5 speed. Your car sounds great.
  22. straightlinespeed
    straightlinespeed Sometimes I pretend to be normal Staff Member FABO Gold Member
    9,294
    2294
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    9:41 PM
    Awesome!!!! Have fun with that car!
  23. Crazy4408pac
    312
    3
    Jan 3, 2010
    Local Time:
    10:41 PM
    410 gears. 8 3/4 489. Cope Racing built 727. Forward manual valve body. Cope TC 3000-3800.
    I ported and polished the heads and intake. gasket matched intake and exhaust ports. It has 9.6 to 1 compression
    I installed an Ohio Crank 572 kit.
    These are the specs:
    4340 4.5" stroke 8 bolt crankshaft
    JE Custom flat-top pistons
    OC 7.1" H-beam rods w/ARP 2000 bolts
    Total Seal rings FM race bearings
    Internally Balanced
    Hears the cam kit I'm running.
    RPM Range: 2600 - 6600
    Lift with 1.6 Rocker: .560"/.565"
    Duration @ .050": 243/251
    Advertised Duration: 294/302
    LSA/IAC: 110/106
    Valve Lash: Hyd/Hyd
    Cam & Lifter Kit: 20230713LK
    Complete Kit: 20230713K
    Lifters: 72338-16
    Springs: 73121-16
    Retainers: 75748-16
    Locks: 77127-16
    Valve Spring Kit: 73121K5
    Valve Seals: 78505-16
    Timing Set: 94225
    Pushrods:
    Rocker Arms: 85370-16
    This is the first Auto trans hot rod I've ever built. Lost my left leg below the knee, last year. No biggie, just can't shift the 833s anymore. At 67 yo, this will most likely be my last build.
