Fitech EFI Rpm Noise Solved
Forced Induction Mopar
  1. superchargeddrt
    superchargeddrt FABO Gold Member FABO Gold Member
    1,949
    536
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    2:41 PM
    After considerable issues with the dreaded RPM noise fault code and the engine just shutting off for no apparent reason I have a solution. I had to route all of my Fitech wiring away from any high voltage ignition wires (particularly the magnetic pickup coil wire). I also wrapped the pickup wire with aluminum foil and the coiled bare stainless steel wire around the foil and finally wrapped it all in a wire covering to make it look better. I then grounded the end of the wire connected to the foil from the connector to the throttle body to one of the throttle body mounting studs. The other end of the the connector to the distributor is grounded to the distributor with a screw running up through an unused threaded hole. Additionally I made a metal shield to go around the pickup coil inside of the distributor. This is held in place by the coil mounting screws. So far this is idling great with no fault codes. I couldn't drive it yet because of bad weather but I will post another video soon.
    Here's the video link. I hope that this helps.
    • Like Like x 2
    • superchargeddrt
      1,949
      536
      Aug 24, 2009
      Pittsburgh, Pa.
      Local Time:
      2:41 PM
      • Like Like x 3
      • superchargeddrt
        1,949
        536
        Aug 24, 2009
        Pittsburgh, Pa.
        Local Time:
        2:41 PM
        Now all I have to do is figure out how to setup the timing for both advance as well as retard. I don't have a clue yet but I will let you guys know when I find out. If anyone knows how to set this up please feel free to post.
        • Like Like x 1
        • superchargeddrt
          1,949
          536
          Aug 24, 2009
          Pittsburgh, Pa.
          Local Time:
          2:41 PM
          By the way excuse the little air cleaner. That is on there because I couldn't use my dropped base with the straight fittings. I am going to put my dropped base and scoop seal back on as soon as I can get it out of my loft.(Dart is sitting right where I need to put the ladder so it has to be moved.
          • Like Like x 1
          • 67Dart273
            67Dart273 Well-Known Member
            38,648
            6256
            Oct 14, 2010
            Idaho
            Local Time:
            11:41 AM
            I'm not tryin to say "I told you so" but there is plenty of this kind of problem out there. One way I used to create braid shield.........and you can buy shield separate.........is to carefully strip the outer jacket of some coax cable. Not TV cable, usually, but CB/ radio feedline, RG-58/ 59, RG-8 etc. You can "bunch" the braid up by pushing it to make it larger to thread the wire, then smooth / stretch it out.
            There was on guy had an MSD interfere with a Mopar voltage regulator. Stuff like MSD is particularly troublesome because there is so much power there
          • superchargeddrt
            1,949
            536
            Aug 24, 2009
            Pittsburgh, Pa.
            Local Time:
            2:41 PM
          • superchargeddrt
            1,949
            536
            Aug 24, 2009
            Pittsburgh, Pa.
            Local Time:
            2:41 PM
            A couple more videos.
            Fitech idle after cold start.
            Fitech Dashboard
            • Like Like x 1
            • 67Dart273
              38,648
              6256
              Oct 14, 2010
              Idaho
              Local Time:
              11:41 AM
              !!NICE!!
            • superchargeddrt
              1,949
              536
              Aug 24, 2009
              Pittsburgh, Pa.
              Local Time:
              2:41 PM
              Thanks
            • T56MaxTorq
              T56MaxTorq Well-Known Member
              830
              226
              Dec 21, 2010
              CO
              Local Time:
              12:41 PM
              Good call on the shielded wiring. Every low amp ac circuit is supposed to be shielded from noise as much as possible. The pickup coil (Hall effect, variable reluctor, etc) doesn't necessarily need to be shielded but the wiring is a must because wiring acts as an antenna and electrical noise (starter, coil, msd, plug wires, overhead power lines, radio freqs) will alter the ac signal and give you crazy rpm/cam/crank timing readings. Not what we want with a boosted V8.
              Megasquirt made it hard for me and I faught it til i finally realized i needed a pull-up resistor in line with the pickup.
            • 67Dart273
              38,648
              6256
              Oct 14, 2010
              Idaho
              Local Time:
              11:41 AM
              There is also a strategy with BALANCED circuits. Old copper phone lines, and the old TV twinlead are examples of this. Because the wiring is (supposed to be) balanced, it picks up noise equally in both conductors, and this actually causes a cancelling effect.
              If you remember TV twinlead, you twisted it....this was to help maintain balance and aid in cancelling noise. Even old telegraph/ telco wires were twisted to maintain balance, AND IN FACT THAT is how ethernet cable works--------CAT-5..
              Here is a twist in a telegraph/ telco line. It is for one reason........to maintain balance and to cancel noise
              It is recommended to twist wiring such as the Mopar ECU pickup. This actually may not be as effective in this case, because one leg of the pickup circuit is actually grounded in the ECU. Nevertheless it helps form a shield. This low current "signal" wiring should not only be run away from powerful circuits, especially ignition, but near a "ground plane" that is the firewall
              • Agree Agree x 1
              • dusterbnb
                dusterbnb Well-Known Member
                173
                61
                Sep 12, 2013
                Missouri
                Local Time:
                2:41 PM
                They do this same thing on 1939 data link connectors on the trucks I works on. All the data wires are twisted for shielding, like 67dart273 said.
              • 70wayfarer
                70wayfarer Well-Known Member
                409
                25
                Jul 20, 2011
                new zealand
                Local Time:
                7:41 AM
                cool car. how do you rate the fitech set up.
              • superchargeddrt
                1,949
                536
                Aug 24, 2009
                Pittsburgh, Pa.
                Local Time:
                2:41 PM
                Thanks,
                The Fitech setup works well but it is not plug and play (nor is any other FI setup) The basic settings will get you up and running but you are going to have to do some of the tuning yourself. Also you are going to have to shield some of the wiring to avoid the RPM noise error. There is a lot of help here on this forum. PM me if I can help.
                • Agree Agree x 1
                • my68barracuda
                  my68barracuda Well-Known Member
                  530
                  158
                  Dec 6, 2009
                  Indianapolis IN
                  Local Time:
                  2:41 PM
                  I had a similar RPM noise issue with a Mega Squirt install, massive interference would not allow the motor to start / run.
                  the MS 3 Pro harness that attached to my distributor leads, I am using a locked lean burn distributor, had foil grounded insulation inside of the wire bundle, I found an EMI / RF article that stated there are times when grounded fol is not enough, and the fix is to add woven wire shielding over the foil.
                  and that was my fix for the RF interference. For the EMI side I moved the main engine block ground from the cylinder head to one of the starter mounting studs and all was good.
                  below is a link with additional info
                  After Market ECU's and EMI interference - Slant Six Forum
                  also the woven wire sheathing is available in wire size diameters, 1/8, 1/4, 3/8 ,,, for not much money, I think I paid $9.50 shipped for 10 feet of 1/4 inch diameter braided wire sheathing. Got mine from Electriduct e bay store
                  also, whether it is foil or woven wire, only ground one end of the shield.
                  • Thanks! Thanks! x 2
                  • grimreaper
                    grimreaper Cross Member
                    3,705
                    485
                    Jul 8, 2005
                    Gillette, WY
                    Local Time:
                    12:41 PM
                    With RPM noise being the known issue it is, I wonder why FItech doesn't provide the units with shielded wire?
                    • Like Like x 1
                    • Agree Agree x 1
                    • famous bob
                      famous bob mopar misfit
                      11,238
                      2784
                      Aug 14, 2011
                      okla
                      Local Time:
                      1:41 PM
                      I have had NO problems with any of this stuff with my fast 2.0 f.i. system, from day one !.
                      It has worked flawlessly so far-------------all I`ve had to do is lean it out from the initial start up self learning, and go to hotter plugs.
                      May need more timing in it too, but is super easy on the handheld.
