Fix for Cowl Shake and Body ?
Convertible A-Body Mopar
  1. GaryS
    GaryS Well-Known Member
    672
    49
    Nov 5, 2009
    Ponder, TX
    Local Time:
    8:47 AM
    It's not bad on my restored and modified daily driver '64 200, but it is noticeable at in-town street speeds.
    I've been told that brand Cs use some kind of counter balance weights in their convertible fenders to dampen movement, but that sounds like something that needs calculated engineering with extensive testing and doesn't sound feasible for retrofitting our convertibles.
    Despite all new seals and weather stripping, adding expensive sound deadening materials throughout and upgrading under-carpet padding, closing the doors makes the posts shake and the doors reverb until it sounds almost "tinny". I've seen braces to help control frame twisting for racing and handling, but I've never seen anything designed to stiffen or dampen vibration in other parts of the body to improve overall rigidity and reduce noise.
    Anyone else thought about doing this?
  2. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    7,450
    5087
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:47 AM
    Na... It's a convertible, I can't hear anything after driving for an hour on the interstate. When I drive with the top up, I hear all kinds of noises, but it is a 54 year old car not a modern plastic disposable car.
    Just my 2 cents.
    Many cars have spray on panel stiffener like that in our trunks on the quarters.
    Anything to thicken the sheet metal will reduce the tinny sound you talk of.
    • Agree Agree x 2
    • Jim Lusk
      Jim Lusk Well-Known Member
      5,218
      1612
      Mar 8, 2006
      Fresno, CA
      Local Time:
      6:47 AM
      Subframe connectors will help some, not just for drag racing and road racing. We never put them on the GTS convertible and likely never will, but you can tell a VERY noticeable difference in total stiffness between it and my son's '67 Dart convertible, even though the '67 has a 440 to add more weight.
      • Like Like x 1
      • jbc426
        jbc426 Well-Known Member
        2,051
        875
        May 30, 2007
        West Coast
        Local Time:
        6:47 AM
        I have a '68 Barracuda convertible that I welded in the full US Cartool Chassis Stiffening Kit. I made a huge difference, but I still had a bit of the cowl shake left. It was most noticeable around town.
        When I still had the Slant 6 under the hood, I made a Monte Carlo bar that tied the cowl and fenders together. It consisted of 3 tubes that formed a triangle and attached to several of the inner fender bolts and the pinch weld above the wiper motor.
        This Monte Carlo bar stopped the remaining cowl shake.
        It no longer fits with the 5.9 Magnum & A/C I installed, and I haven't bothered modifying it for the V8.
        • Like Like x 1
        • GaryS
          672
          49
          Nov 5, 2009
          Ponder, TX
          Local Time:
          8:47 AM
          Thanks for the replies. I already have a lot of "Road Kill" sound deadener material installed, but next spring I'll do a better job by installing more, especially in the trunk and quarters.
          I'm also going to find out about the US Car Tool stiffening kits and see if there is a way to reinforce the door post latch pin area. I don't think the bar idea would fit with my A/C setup.
        • sccachallenger
          sccachallenger Well-Known Member
          326
          134
          May 18, 2015
          north carolina
          Local Time:
          9:47 AM
          A fiends '73 Swinger 383 always felt kind of flimsy when closing the doors. Might be why many suffer cracks around the door strikers. Even a basic homemade set of sub connectors will help. I mean compared to a sedan, no pillar, and no roof! What do we expect from 50+ year old metal?
          • Agree Agree x 1
          • A56
            A56 MoPar Affliction
            4,896
            12317
            Jun 24, 2014
            South of the Mason-Dixon Line
            Local Time:
            7:47 AM
            These are in production from USCT (inner rocker sill brace) and they are for A bodies. Very similar to what was used in E body convertibles from what I've read. The only down side is the lower outer rocker panel on each side has to be removed. I'm presently waiting for them to be released.
            b%20body%20rocker%20stiffener%20assembly%20v5_thumbnail.png USCT1M2048%20Installed%201%20small.jpg
          • burdar
            burdar Owen's Dad
            1,233
            291
            Aug 15, 2013
            Iowa
            Local Time:
            8:47 AM
            Starting in 74, the factory added bracing from the firewall to the fender tops. They were getting complaints of cowl shake and this was their fix. I'm adding them to my 68. Since the pinch weld on the firewall isn't wide enough for the braces(the factory widened the pinch weld in 74) I made up some aluminum extensions to give me a place to mount them. I think they will look fine on the 68. The main thing is that I'm not going to try and color match them to the car. They will just be matte black. Anything else and I think they would stick out like a soar thumb.
            • Like Like x 2
            • Thanks! Thanks! x 1
            • 4spdragtop
              4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
              32,429
              13177
              Aug 28, 2009
              Wasting time here
              Local Time:
              8:47 AM
              :thumbsup:
            • sccachallenger
              326
              134
              May 18, 2015
              north carolina
              Local Time:
              9:47 AM
              Like your idea!
              Hope your "soar" thumb feels better soon:)
