Flaming river columns.
Suspension, Steering and Chassis
  1. jmwuva05
    jmwuva05 Well-Known Member
    46
    18
    Sep 9, 2021
    Virginia usa
    Local Time:
    4:36 PM
    Hello new member first post outside the welcome section threads. I have a 72 duster that came from the factory with manual steering. I bought the cat as a rolling chasis and it has a lot of nice suspension and chasis upgrades. Interestingly it has an electric power steering unit which works pretty well when I hooked up but I don't think I want to use it. I am planning on a 408 with manual transmission and I think it will interfere with a clutch. The car is factory automatic but looking at 4 speed car pictures inthinknthe electric motor under the dash will interfere. I also plan to get a flaming river colum qith tilt. To get to my question I plan on using one of the new more compact borgenson ps units and was wondering if anyone has one of those installed with tti headers and could give me some guidance on clearances with that set up. Also has anyone used one of those units with a flamingnriver column? Thanknyounin advance
  2. jimjimjimmy
    jimjimjimmy lobsterman FABO Gold Member
    4,693
    1536
    Nov 2, 2010
    p. e. i.
    Local Time:
    5:36 PM
    i dont want to get your thread off track but i would like to know more about your electric power steering assist . maybe i can pm you ?
  3. jmwuva05
    46
    18
    Sep 9, 2021
    Virginia usa
    Local Time:
    4:36 PM
    I just pulled it out of the car and will post some pics. The car had been a racer and the previous owner who I didn't meet had a 440 shoehorn in it. He took it out to use it in a charger I believe. So it makes since why he wanted the electronic power steering too me. I bought it at hodge mopar restoration in Spartanburg sc. I used to live down there and had followed his shop on Facebook. He has some amazing stuff and is a top notch guy. He wasn't sure about the specifics on the unit but said he had seen them before. It is made by koyo and is stamped Mitsubishi electronic corp.
  4. jmwuva05
    46
    18
    Sep 9, 2021
    Virginia usa
    Local Time:
    4:36 PM
    Here Are the pics
    • Thanks! Thanks! x 1
    • roccodart440
      roccodart440 Well-Known Member
      5,872
      4821
      Apr 19, 2010
      Local Time:
      4:36 PM
      2 things..
      A 440 in an Abody is not a shoehorn fit.
      Electric powersteering is very viable and BMW uses it on their MC line
      I'd check TTI site and they are accessible by phone if you need more info or clarification.
    • jmwuva05
      46
      18
      Sep 9, 2021
      Virginia usa
      Local Time:
      4:36 PM
      I may be exaggerating a little bit on the 440 being shoehorned Certainly if that engine was still in the car I would leave it but it got taken out to put in a charger by the PO. I now the electronic steering units are reliable in a lot of major manufacturers and my wife's last car actually had one and I couldnt tell the difference in it and my traditional power steering ram 1500. I really want a manualntransmissiin and the way this thing is grafted into the column I don't see how on earth a clutch pedal could clear it. I can do basic welding and fabricating but don't thinkni could modify a clutch pedal adequately to clear it and get the right geometry. Also I really want a tilt column as I like to drive with the wheel near straight up and down. I am waiting to hear back from flaming river on which column would work best with a borgensen steering box as they seem shorter than a factory power steering box front to back length wise.
    • roccodart440
      5,872
      4821
      Apr 19, 2010
      Local Time:
      4:36 PM
      YOu could eliminate the Z bar and go with a hydraulic clutch
      • Like Like x 1
      • Scody21
        Scody21 Just send it
        819
        774
        Jul 17, 2019
        Southwest Washington Coast
        Local Time:
        1:36 PM
        Isn’t the power steering unit in the gas peddle side of the column?
      • jmwuva05
        46
        18
        Sep 9, 2021
        Virginia usa
        Local Time:
        4:36 PM
        Yes the motor unit cants toward the fuel pedal which is another problem as my size 14 shoe hits it. The central body of the unit where it interfaces the column is pretty thick and the PO removed some of the metal bracketing to get it to fit over where the clutch would go. Not a lot of metal perhaps about a 1/4 inch strip. I will post some pictures of that mod later this evening when I get home.
      • jmwuva05
        46
        18
        Sep 9, 2021
        Virginia usa
        Local Time:
        4:36 PM
        Yes I had thought of that especially if I chose to use a tremec 5 or 6 speed
        • Like Like x 1
        • jmwuva05
          46
          18
          Sep 9, 2021
          Virginia usa
          Local Time:
          4:36 PM
          Wiring for the electric assit
        • kursplat
          kursplat FABO Gold Member FABO Gold Member
          4,221
          3161
          Aug 24, 2010
          so cal
          Local Time:
          1:36 PM
          @BergmanAutoCraft will have some intel for you
        • jmwuva05
          46
          18
          Sep 9, 2021
          Virginia usa
          Local Time:
          4:36 PM
          Thank you I will try to call them Tomorrow looks like they have some sweet kits on their site
        • BergmanAutoCraft
          BergmanAutoCraft FABO Vendor FABO Vendor
          259
          200
          Feb 18, 2013
          Long Island, NY
          Local Time:
          4:36 PM
          The small block TTI header with this box doesn’t create any issue. Let me know exactly which column you’d like and I’ll be happy to price it for you.
          • jmwuva05
            46
            18
            Sep 9, 2021
            Virginia usa
            Local Time:
            4:36 PM
            Awesome thank you for the reply! I definately want a tilt column just haven't decided on stainless or black powder coat. I will contact you in the next day or two. I am going to be out of town on buisness tomorrow but will be in touch
            • Like Like x 1
