1. Slantsix64
    Slantsix64 Well-Known Member
    3,156
    1324
    May 11, 2014
    SGV
    Local Time:
    6:29 AM
    I use flex fans on all my mopars 18inch. They run cool all the time and pull a shit ton of air in it. I spin my barracuda 6k no issues.
  2. ir3333
    ir3333 Well-Known Member
    5,076
    1590
    Jun 1, 2008
    ontario,canada
    Local Time:
    6:29 AM
  3. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    77,847
    55277
    Jun 7, 2010
    Georgia
    Local Time:
    7:29 AM
    All I can say is he'd be dead if it hit him across the neck.
    • Agree Agree x 3
    • ir3333
      5,076
      1590
      Jun 1, 2008
      ontario,canada
      Local Time:
      6:29 AM
      i agree!
    • 1969383S
      1969383S FABO Gold Member FABO Gold Member
      6,514
      3472
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      7:29 AM
      I lost one "Flex Fan" in 88 on the way to the pro-street race in Dallas Ga. and it ripped the radiator apart. Cost me a tow home I really could not afford + a new 3 core 24" radiator and more!
      It never cooled well, even with the 18" pusher electric!
      My suggestions have been posted over and over again on this forum and it really is simple!
      My 22" 3 core from Glenray with all the factory Stock pieces is Absolutely 100% The Best hands Down! I have never been happier and Cooler!
      My bad as forgot to mention the High Flow 185 Thermostat which technically is not stock!.
      • Agree Agree x 2
      • famous bob
        famous bob mopar misfit
        19,852
        8819
        Aug 14, 2011
        okla
        Local Time:
        6:29 AM
      • kiwigtx
        kiwigtx Well-Known Member
        233
        442
        Sep 2, 2010
        New Zealand
        Local Time:
        12:29 AM
        This one was entertaining enough. :lol:
      • dave ellis
        dave ellis Well-Known Member
        70
        11
        Dec 30, 2012
        jacksonville, florida
        Local Time:
        7:29 AM
        what is the shortest one you found, 2947? how tall is it? thanks, Dave
      • famous bob
        19,852
        8819
        Aug 14, 2011
        okla
        Local Time:
        6:29 AM
        notice how close the mounting bolts are between the water pump and fan
        IMG_0469 (3).JPG IMG_0470 (1).JPG IMG_0475 (1).JPG re -------------
      • RustyRatRod
        77,847
        55277
        Jun 7, 2010
        Georgia
        Local Time:
        7:29 AM
      • famous bob
        19,852
        8819
        Aug 14, 2011
        okla
        Local Time:
        6:29 AM
        didnt say it was a flex, was asked how long the clutch was , pics because I couldn`t remember .
      • RustyRatRod
        77,847
        55277
        Jun 7, 2010
        Georgia
        Local Time:
        7:29 AM
        Gotchya. I like the clutch. What is the part number again?
      • famous bob
        19,852
        8819
        Aug 14, 2011
        okla
        Local Time:
        6:29 AM
        think its a 2947 , ben on a while .
      • RustyRatRod
        77,847
        55277
        Jun 7, 2010
        Georgia
        Local Time:
        7:29 AM
        • Thanks! Thanks! x 1
        • ir3333
          5,076
          1590
          Jun 1, 2008
          ontario,canada
          Local Time:
          6:29 AM
          I have used new Mopar clutch fans on three different occasions but found mine were barely adequate.
          Problem is they only turn about 80% shaft speed at idle in heat when you need them most. They
          also have clearance problems as you have found out, are very heavy and that weight is out on the
          end of the water pump shaft...not good. Lastly they fail and it is very hard to tell.
          For best cooling get a new 10,000 rpm flex fan or better still 7 blade mechanical.Make sure it has
          as much pitch as you can use.
        • dave ellis
          70
          11
          Dec 30, 2012
          Local Time:
          7:29 AM
        • dave ellis
          70
          11
          Dec 30, 2012
          Local Time:
          7:29 AM
          I have read that the standard fan clutch turns at 75% of pump speed. An RV clutch turns at 90% if that helps you
        • dave ellis
          70
          11
          Dec 30, 2012
          Local Time:
          7:29 AM
        • dave ellis
          70
          11
          Dec 30, 2012
          Local Time:
          7:29 AM
          I could live with that if it will put a clutch on the car. Thanks much, I have been trying to find a solution for this for a while.
        • dave ellis
          70
          11
          Dec 30, 2012
          Local Time:
          7:29 AM
          I could live with that as long as it puts a clutch on the car. Thanks much, I've been trying to find a solution to this for a while.
        • Krooser
          Krooser Reform School Graduate
          3,274
          2811
          Jul 19, 2015
          Central Wisconsin
          Local Time:
          6:29 AM
          Flex Fans do eat a lot of hp. I will try a Mopar 4 blade nect racing season
        • Alipiama
          Alipiama New Member
          4
          2
          Sep 24, 2021
          usa
          Local Time:
          2:29 PM
          Thank you for sharing
