1. tjpatte
    tjpatte Well-Known Member
    238
    124
    Jun 22, 2015
    San Diego
    Local Time:
    10:07 AM
    Below are the pictures of my crank and TC after about 4 months and 1500 miles. The snout of the TC was tight in the crank when I put it together (didn't know better always a stick guy before). Had the proper clearance between the TC pads and flex plate before pulling it forward. Noticed the crank walking one day and found I had about 0.032 crank movement and a wiped thrust bearing.
    Good info on TC dimensions and clearances, surprisingly little out there about this.
    Torque Converter info for various transmissions
    • Like Like x 1
    • Thanks! Thanks! x 1
    • tjpatte
      238
      124
      Jun 22, 2015
      San Diego
      Local Time:
      10:07 AM
      Mine was perfectly flat.
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        14,830
        3903
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        12:07 PM
        Ouch! Kim
        • Agree Agree x 1
        • Jadaharabi
          Jadaharabi FABO Gold Member FABO Gold Member
          7,102
          7594
          Jan 8, 2016
          Peoria, Illinois
          Local Time:
          12:07 PM
          There you go.
          • Like Like x 1
          • Dusterdenovo
            Dusterdenovo Contentedly Old School
            965
            1827
            Dec 10, 2011
            British Columbia
            Local Time:
            10:07 AM
            You guys might find this interesting:
            While I have been talking with Hughes today about possibly shipping the TC back to them, I also put in a call to B&M (Holley Group) to ask them a few questions about the flatness of the Flex Plate etc. While I do not have plans of doing this, here is what I was told:
            "There is not a set tolerance on flexplates. It can vary from 1/8” up to ¼” when they are setting flat and not bolted to anything. Bolting to a converter and crankshaft is what straightens them up"
            NOT part of my plan, but interesting enough to share.
            • Like Like x 1
            • tjpatte
              238
              124
              Jun 22, 2015
              San Diego
              Local Time:
              10:07 AM
              Yep, I found the same thing in my endless search for information on what went wrong. I was worried about mine since I had to pry it apart, but thankfully it stayed straight.
            • 12many
              12many Well-Known Member
              1,128
              1384
              Dec 14, 2016
              SC
              Local Time:
              12:07 PM
              I’d also be worried about how the centerline of the converter as mounted to the crank lines up with the trans centerline, the pump bushing won’t like anything being off as I believe that is mentioned in the B&M paperwork. Think rapid bushing wear and leakage. Line boring of the block changes alignment, and while an oem flexplate actually flexes and is more forgiving the B&M doesn’t and isn’t. Pretty damn rigid as I’m sure you’ve noticed. Have you checked crank pilot depth, and the converters pilot? Difference in positioning from block/trans mounting surface of the oem plate vs. the B&M? Likely some hardened sae washers (Hillman brand at better hardware stores) is all you’ll need but lots to check over.
            • Dusterdenovo
              965
              1827
              Dec 10, 2011
              British Columbia
              Local Time:
              10:07 AM
              Yup. Sent a number of pictures over to Hughes today. Their guy has been pretty attentive to the problem so I'll see what he says after his guru looks at it.
            • Jadaharabi
              7,102
              7594
              Jan 8, 2016
              Peoria, Illinois
              Local Time:
              12:07 PM
              • Like Like x 1
              • tjpatte
                238
                124
                Jun 22, 2015
                San Diego
                Local Time:
                10:07 AM
                When you look at the B&M you would think it doesn't flex (I know I did), but it actually does. How much, I can't say, however after my second go around I found marks that showed movement.
                Agree with the alignment and currently making sure that the snout is aligned with the center of the crank so there is no pressure points.
                I guess the point I'm trying to make is that the TQ needs to be able to slide inside the crank to allow for fluctuations in tranny pressure surges and that the flex plate flexes.
                • Agree Agree x 1
                • oldkimmer
                  14,830
                  3903
                  Nov 11, 2006
                  Local Time:
                  12:07 PM
                  And the snout needs to be greased up so it can move easily. I know most ppl skip that step. Kim
                  • Agree Agree x 1
                  • tjpatte
                    238
                    124
                    Jun 22, 2015
                    San Diego
                    Local Time:
                    10:07 AM
                    Yep, I use anti seize.
                    • Agree Agree x 1
