parts of the pan will fit perfect, other parts like the seat mounting shape, the tunnel hump is bigger and the definition lines are in a different spot. with that being said here is a shot of the rear section af a 73 dart floor pan grafted onto autobody specialties front floor pans and holes cut out to fit the newer style sebring seats.Will a floor pan from a 67+ work in an early A body (64,65,66)????
Who sells them?With some work it will, but they sell the early A body floor pans so why not get the correct ones??
Who sells them?
Autobody Specialtys in Ct .The ones I just got in this car deal have Laysons labels on them! I would try contacting member "Rick@Laysons" and see if they are still stocking them!!
X2. Mine fit like a glove on my '66.Autobody Specialtys in Ct .
I just found that front and rear on both sides of my 65 4dr is rusted clean through. Been sitting a few years. Something tells me rain water has found a way in!! GRRRFinally somebody stepping up and keeping us in mind!!!
I have a donor '66 that I have been using for parts for CUDAVRT. I cut the 4-speed cap out for the v8/4-sp conversion. The remaining pan is useable, and you are welcome to it if you want to come here and remove it. I'm in nor cal. PM me and I will send you pics.Will a floor pan from a 67+ work in an early A body (64,65,66)????
