360 X 1.7 = 600+ HP I don’t see it. OOTB EDELBROCK heads? Well, not for a street vehicle at least. Nor N/A. With 250-ish or so cfm on the intake, I see the head and it’s port window a bit shy for the job. I suppose it is possible at the extreme end of pushing a lame head for the HP goal of 1.7, through the ceiling. Again, I just don’t see it on the street in any kind of popularity if at all. I do t know why you would want to try and shove that head through the ceiling when there are better heads to more efficiently make more power over a broader scale. It would be all so way crazy worth it to pony up the money and not be a cheap *** here.But also there's a ton of guy's that just put together ootb Eddy heads airgap some kind of 280 cam and some 10:1 pistons, and get a reasonable 1.7-1.8 hp per cfm.
Posted by PRH and I quote;I also think it is not a problem. Going past the theoretical isn’t a normal street engine type of build. Also probably not what you would want to do on a NA engine. This is more likely race territory for most. It may very well be, not a very friendly driver at this point.
This is exactly the kind of thing I was thinking about. Same guy.Brett Miller built a Victor headed 440” SBM a couple years ago.
Made over 1000hp with heads that flowed under 400cfm.
Unless you just want to beat your chest or your rule limited. However that would work! LMAO! Imagine reading that rule.... Edelbrock RPM “ONLY!”
