[WANTED] Flywheel for '63 Slant 6
Theres two parts cars in the W side pick a part. Anthony, TX. Next to the La Tuna federal Prison. '63 Wagon, and '64 Sedan. Both are Stick cars. Guessing that is a 350 mile round trip for you.
Dave S
Dave S
Careful on the flywheel out of that car. The engine looks to be a later model and may have a later crank and flywheel. The one for a '63 has the small I.D. that was used up through '67. '68 and later use the larger diameter one.
Lemmie look. I think I have one.
No, I'm sorry. I do not. Well, I do, but it's on the back of the 170 I pulled out of Vixen and I'm not selling that one. I do have an extra one for the large crank register though, if for some reason you go that way.
Yes the "red" engine in the '64 sedan is a later engine, '68 as I recall. Anyway, just throwing it out there, these cars were close enough to the OP's location.
I'd recommend you take some measurements before you ship. A lot of A100 and pickup engine parts were a bit different than the ones in the same year car. The Van's and PU's didn't use 904 transmissions, so the crank had to have a larger converter register.
