Fontana Auto Club Dragway Wed Night Lights
West-Coast
  1. Jesus Chrysler
    Jesus Chrysler Forgiving Sins Against Mopar Since 1983
    270
    216
    Feb 5, 2018
    Ontario, California
    Local Time:
    2:11 PM
    Has anyone run their car at the Wednesday night street legal events?
    I'm curious how thorough their inspection is. I have a 67 FB barracuda and the rules state that cars with filler necks located in the trunk require a steel bulkhead separating the driver compartment. Currently there is only the plywood folding panel. I suppose I could slap some sheet metal on it and it should be okay, but I'm interested to know what other peoples experience has been. I'm also not sure if they mean any filler neck that passes through the trunk or if they're only referring to necks that fill from inside the trunk like on a fuel cell.
  2. ocdart
    ocdart Inland Mopars Car Club FABO Gold Member
    9,729
    3070
    Nov 5, 2006
    North OC, SoCal
    Local Time:
    2:11 PM
    First off, I think you're going to have to head a little further east. The 'Wednesday Night Lights' are at Auto Club Dragway in Fontana.
    I don't know for sure but I can't imagine you would need a steel bulkhead separating the trunk from the driver/passenger compartment for a stock fuel filler setup. It's a common rule to require a metal bulkhead if you're running a fuel cell that fills from inside the trunk - also if you've relocated your battery to the trunk.
  3. Jesus Chrysler
    270
    216
    Feb 5, 2018
    Ontario, California
    Local Time:
    2:11 PM
    You are correct. I didn't realize I was looking at Fontana.
    I was thinking it was referring to fuel cells, but the verbiage is pretty vague.
  4. flingdingo
    flingdingo Well-Known Member
    349
    272
    Apr 26, 2017
    El Lay
    Local Time:
    2:11 PM
    How modified is your car? If it is basically stock, you're probably fine. If its got a bunch of power adders, slicks, cage, etc... they'll probably get a little more sticky.
  5. Jesus Chrysler
    270
    216
    Feb 5, 2018
    Ontario, California
    Local Time:
    2:11 PM
    Mostly stock. Barely modified at all
  6. flingdingo
    349
    272
    Apr 26, 2017
    El Lay
    Local Time:
    2:11 PM
    I've only ever drag raced nearly stock cars, and never had a problem with tech. They have looked at things like, leaking fluids, working seatbelts, etc. Take the car down and have them take a look... the worst they will say is no. But you will know what they want you to fix.
