FOR SALE 67 68 69 70 71 Rallye Dash Gauge Circuit Boards Cuda Dart Duster 340
66340SEDAN
FABO Member #3649
Minnesota
For sale is a bunch of used circuit boards, bigger boards have part number 2771651 on them, the smaller ones have part number 2771652 on them. 2 different colors but all appear to be the same.
5 of these...The bigger one, part number 2771651, 2 only have 1 pin missing on the back, the other 3 each have 3 pins missing. I believe these can be fixed, otherwise they look nice and clean, not fried either. $5 each
4 of these...The smaller ones, part number 2771652, one has all the pins, one is missing 1, the other 2 have 2 missing 2. I believe these can be fixed. $10 for the one with all the pins, $5 each for the others.
Shipping will be $5 wether you want 1 or all of them. They are going in a small flat rate USPS box to make sure they arrive safe, they won't survive being shipped in an envelope. I am in central MN, thanks FABO!!
I've seen the top pin broke out of that small board too many times. I guess it gets hit when the panel is going in/out of the dash. I recently saw a cure for it too. The original connector had the wires cut and a pig tail from a trailer harness added on. That moves the service disconnect to a remote location so the factory connector never needs pulled off the board pins again. Any 3 wire connector could be used. The trailer hitch connectors were a nice choice though since it has a similar appearence.
I "sorta" did the same thing to mine with both connectors, used Molex style connectors from Radio Shack. My originals were all torn up badly
Good to know, Thanks for the tips!!
Still have...maybe pins from one can be soldered back on another that is missing them? Anyone?
