[SOLD] FOR SALE: Weiand Aluminum 4bbl Intake Manifold #7507 Mopar Small Block 340-360
66340SEDAN
FABO Member #3649
Minnesota
For sale is a used Weiand aluminum four barrel intake manifold #7507. It is painted and in clean shape, all gasket surfaces clean and nice. The is a small crack at the left front coolant port, (see pics) I was told this should be an easy fix. The crack doesn't appear to be inside the port, just on the outside and on the intake gasket surface, the crack doesn't go to the bottom at the front side where it meets the block. I never used this, just noticed the crack after I got it. I was always gonna fix it but its been sitting around for too long so it needs a new home. I think this intake is more for the 340-360 heads, very similar HP gains like the old Eddy LD340 intake. This intake will accept most standard 4 bbl carbs like an Carter/Holley, but not a spreadbore desgin. The intake has been gound down a little where the valve covers meet the intake, there is a little tab sticking up, no biggie, just means you don't have to grind your covers to fit. The last 2 pics 2 intakes are pictured, this is for the painted one, the bare intake is for sale in a seperate for sale ad. Sold as is, $90 shipped to your USA door, I am in central MN, thanks FABO :glasses7:
