forged 340 stick and auto crank bolt patterns the same?
LXguy
Champaign IL
Hey All:
Just to verify:
Is the only difference between a stick and auto 340 crank the pilot bearing?
You can throw a flexplate on a stick crank (after removing pilot) and run it with an auto, right?
I was pretty sure already, just seeking confirmation,
Thanks,
Steve
do you have to remove the pilot bushing to put a flexplate on it..?
but yes..the cranks are the same ....
Thanks guys. I thought you had to remove the bushing so the converter snout would go in properly.
