1966 fresh 273, .040 over, CR approximately 9.5 to 1, forged pistons, block fully prepped, shot blasted, acid dipped, steel crank, 340 oil pump, windage tray, HiPo 273 solid lifter cam, dumb bell lifters, ARP adjusters, 920 casting heads acid dipped and shot blasted, 1.88 stainless valves cut down to 1.82 to avoid shrouding, valves ground to 5 angle, flow bench tested, Edelbrock LD4B, fresh Carter 9636, , fresh water pump, fresh alternator with mounting brackets.
Asking $3800 out the door
No warranties is stated or implied
Located in Mesa, AZ
Located in Mesa, AZ
