Larryss Well-Known Member Joined Dec 28, 2020 Messages 89 Reaction score 22 Location Berea, ky May 11, 2021 #1 I have a 75 valiant with drum brakes on the front. How to I get the drum off I can't seem to get it off
SGBARRACUDA ROY Legendary Member Joined Dec 7, 2006 Messages 22,009 Reaction score 10,660 Location PLANT CITY FL. May 11, 2021 #2 Remove the bearing cap, cotter key, spindle nut ,washer and outer bearing. It should slide off. If not you may have to back off on the brake adjuster.
Larryss Well-Known Member Joined Dec 28, 2020 Messages 89 Reaction score 22 Location Berea, ky May 11, 2021 #3 SGBARRACUDA said: Remove the bearing cap, cotter key, spindle nut ,washer and outer bearing. It should slide off. If not you may have to back off on the brake adjuster. Click to expand... Thanks
Lord Sparky Well-Known Member Joined Dec 2, 2019 Messages 1,010 Reaction score 953 Location Carlsbad, California May 11, 2021 #4 There’s another similar thread from a few days ago. Brake drum removal HELP
