front end noise
Discussion in 'Suspension, Steering and Chassis' started by Snake, May 16, 2018.
  1. Snake
    Snake Mopar Nut
    9,497
    242
    May 22, 2006
    Belleville Canada
    View My Photos
    Local Time:
    11:17 AM
    Well the 71 is on the road,every thing new in the front end everything,but there is a lot of creaking going on,all oem rubber,it happens when i push up and down on the fender.WEAR to look,any thought out hear. thanks.
    • Like Like x 2
    • 340doc
      340doc Well-Known Member
      1,983
      505
      May 8, 2010
      Hollywood Fl
      Local Time:
      12:17 PM
      My sons Duster was creaking also. I tightened the upper control arm bolts a bit more and it seemed to help. Have someone bounce up and down on the fender while your under the car putting your hand on moving parts feeling for it. That's what led me to the uppers.
      • Agree Agree x 1
      • CUDA69
        CUDA69 FABO Gold Member FABO Gold Member
        669
        61
        Dec 4, 2008
        New Jersey
        Local Time:
        12:17 PM
        Mine did that. My new ball joints needed to be greased, cleared it right up.
        • Agree Agree x 1
        • Snake
          Snake Mopar Nut
          9,497
          242
          May 22, 2006
          Belleville Canada
          View My Photos
          Local Time:
          11:17 AM
          ok thanks will check it out,.
        • brian6pac
          brian6pac Well-Known Member
          3,016
          1509
          Nov 15, 2016
          N.E.Ohio
          Local Time:
          12:17 PM
          Beautiful car, Yea grease the ball joints. I have found if you have someone push the car up and down you can put your hand on each ball joint and feel the one binding up.
        • 694spd
          694spd Well-Known Member
          739
          145
          May 2, 2014
          Upstate NY
          Local Time:
          12:17 PM
          Were the lower control arms pivot bolt nuts and upper A-arms cam nuts torqued with the suspension under load?
          just a thought....
          • Agree Agree x 1
          • Snake
            Snake Mopar Nut
            9,497
            242
            May 22, 2006
            Belleville Canada
            View My Photos
            Local Time:
            11:17 AM
            the lower weer torqued under load,the upper weer tighten under load but not torqued i have yet made it to the alienated shop but are snug for sure.
          • RustyRatRod
            RustyRatRod Just another dumbass. FABO Gold Member
            47,475
            12500
            Jun 7, 2010
            Georgia
            View My Photos
            Local Time:
            12:17 PM
            1) don't push down on the fender. 2) When yall are ridin around, just talk louder.
            • Like Like x 2
            • Snake
              Snake Mopar Nut
              9,497
              242
              May 22, 2006
              Belleville Canada
              View My Photos
              Local Time:
              11:17 AM
              or just crank the tunes up.
              • Like Like x 1
              • RustyRatRod
                47,475
                12500
                Jun 7, 2010
                Georgia
                View My Photos
                Local Time:
                12:17 PM
                I think you're catchin on. lol
              • Snake
                Snake Mopar Nut
                9,497
                242
                May 22, 2006
                Belleville Canada
                View My Photos
                Local Time:
                11:17 AM
                Thank for the help boys,just greased the ball joints more and tighten the upper arms and bounce the front up and down gone,road test will tell more, but its raining now.May 24 for ya.
              • MoparLeo
                MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
                367
                187
                Feb 10, 2016
                Moreno Valley, Cal. So. Cal.
                Local Time:
                9:17 AM
                The noise in my front end turned out to be a old Cat stuck in the sway bar .................................jk
                • Like Like x 2
                • Snake
                  Snake Mopar Nut
                  9,497
                  242
                  May 22, 2006
                  Belleville Canada
                  View My Photos
                  Local Time:
                  11:17 AM
                  Ok up date,after greasing up it went away for a little.However it is the UCR BUSHING,when wrencking on it i could here the noise in the first place they are new Moog.I tighten them as much as i can with a wrench,much better now can only here it barely.How does the alignment shop get a torque wrench in there with the tire in the way?
