I just finished upgrading my 70 Dusters front end. The K-frame and LCA were likely bent due to an accident before I got the car (could see where the K-frame was welded). Replaced the K-frame, LCA/UCA, and strut bars with QA1's. Also replace the torsion bars with PST 1.03's. While upgrading, I installed the Dr Diff Stage 2 front 11.75 disc brake kit.
I greased the UCA's and have gone around everything to make sure things are torqued to spec and when driving slowly (especially decelerating) I hear creaking & noise from the front end. When I installed the new sliding calipers, I made sure the outboard brake pad tabs were bent down to grab the edge so that they would not rattle. At a loss here.
