I removed my front fender plastic splash cards (they rivet to the frame) when I media blasted the car and I am trying to decide if I should re-install them on the finished car. Are they really needed or are they just "nice to have"? Opinions please.
Those shields are there as splash protection from the wheels throwing high velocity water up onto your engine and underhood electrical components. When you hit a decent size puddle, the water is ejected both inboard and outboard of the wheel in a high volume and a high rate of speed.H22A4, You are correct about the frame but I was at a loss to describe the part and location. zkx14 yes, I was referring the K frame shields. My front suspension is Magnum Force tubular so I no longer have torsion bars. I'm trying to understand what these shields will do for me.
what's the panel bond for?Ddaddy, Thank you, that's the piece of data I needed. Wouldn't want to get my pretty coated headers dirty. At $85 pair for new ones it looks like some panel bond is in my future
On the vertical section towards the back (on one of the shields) I'm missing some material and there are some cracks that needed to be bonded. I might have to sandwich the repair.what's the panel bond for?
I would definitely put them back on even tho you will probably not be driving in rain or snow gotta keep it original right?On the vertical section towards the back (on one of the shields) I'm missing some material and there are some cracks that needed to be bonded. I might have to sandwich the repair.
I have an extra set if interested. PM coming your way.On the vertical section towards the back (on one of the shields) I'm missing some material and there are some cracks that needed to be bonded. I might have to sandwich the repair.
