Download the FSM with all the chassis measurements from mymopar.com, you need all the measurements and cross measurements.
Make sure you level the chassis and lay everything out- plumb bob and project the chassis measurements down onto the floor or frame table.
If the car is complete now, level the chassis and take all the measurements laid out in the FSM and record them before taking anything apart. The more measurements you take before you tear the car apart the better off you’ll be when it goes back together.
Take lots of measurements and double check them. These cars are just spot welded together, making sure everything is square and true will be more time consuming than the welding will be.
