Front grille 67 barracuda removal
Shmaako
Winnipeg, Manitoba, Canada
I can spread the stainless moulding apart and the grille seems to simply fit in the groove but has no screws holing it in. I want to remove it so I can paint it.
Is there a trick to separating the grille from the molding?
I taped off chrome to paint due to delicate aluminum
Sheet material. Easily can be bent out of shape. But can be removed gingerly
With patience.
Carefully spread the surround a bit if you want. With enough repeated movement it would break at the pointed end. Open and close once wont be a problem.
