Front suspension rebuilt.. what order to tighten everything?
4fortyDemon
St George, Utah
I'm sure this has been asked numerous times... heres what I've done...
Replaced k member
Replaced lower control arms
Replaced upper control arms
Used the same spindles (has new upper/lower ball joints
Replaced torsion bars with firm feel bars.
What do I tighten in what order?
I know the car has to be on the ground to tighten the lower control arms. Other than that, I don't know.
Thanks in advance!
tighten the ball joints to spec then snug the control arms and get the weight of the car on it. set you ride height then bounce the car and roll it back and forth a bit. Then torque you lower control arms and struts.
This is what I have read and it really made my last front end rebuild ride better.
Thank you! I snugged up the upper control arms and tightened then backed off the lowers to just being snug. I have the front on stands . Need to torque the lower ball joints. Tops are done already.
Appreciate it very much!
