1. GJSZ51
    GJSZ51 Well-Known Member
    96
    5
    Jan 25, 2013
    Raleigh, NC/Miami, FL
    Local Time:
    7:23 AM
    Quick question... Can I run a 235/60 15, with a 4" backspace on a 65 barracuda?
  2. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    31,576
    10469
    May 21, 2011
    Arroyo grande ca
    Local Time:
    4:23 AM
    I don't know,prime time bump....
  3. Keith Mopar
    Keith Mopar Mopar Nut
    2,970
    1152
    May 15, 2005
    Calgary AB.
    Local Time:
    5:23 AM
    That's a really tall tire for the front, 4" back space should work ok. But the biggest on the front with out any trouble that I have found is a 205 60 15. Maybe a 215 if the car isn't sitting to low.
    On my Cuda I ran a 235 60 14 and it cleared on stock rally rims. But they are probably a good inch lower over the 15" rims.
  4. Darter6
    Darter6 Well-Known Member
    4,230
    1513
    Jan 16, 2008
    Nevada
    Local Time:
    4:23 AM
    Not without a little fender clearance. The photos show a 26'' tall tire(same height as a 235/60/15) on a 64 Dart. I had to trim the lower front of the fenders to clear during turns. Had to do the same on a 63 Valiant.
    Not the best photos I hope you can see the triming. First photo the car is lifted on the rack a few inches.Last photo the fender has been trimed.
  5. Darter6
    4,230
    1513
    Jan 16, 2008
    Nevada
    Local Time:
    4:23 AM
    I forgot to ask, how wide of a rim are you using?
  6. 65cudalover
    65cudalover Well-Known Member
    463
    12
    Apr 28, 2010
    Wheeling, Illinois
    Local Time:
    7:23 AM
    I got wide 14 inch rally wheels on my 65 formula S and slightly wider on the back, but all are 14 inch Mopar rally wheels to replace the original 14 inch wheels. Actually the car originally had 13 inch wheels until I replaced the front end with a disc brake kit and rear end upgraded to 8.25 rear from original dinky 7 inch rear. My entire mechanical system has been rebuilt and car was on a rotisserie even upgraded driveshaft to modern ujoint for simplicity and reality of maintenance. Dual brake line set up ect. Its a driver and set up for driving around for fun! I invested my money so far in it for the joy of driving it and seeing people look at it and go what is that! Next expense is the body and paint saving up for that down the road, just drive it now go to shows and evenings at local places others hang out! Its a big boy toy as I refer to it to my wife!
    65Cudalover
  7. cosgig
    cosgig MoBro Inc. FABO Gold Member
    11,339
    4378
    Jul 20, 2008
    Pinckney, Michigan
    Local Time:
    6:23 AM
    Ok, another tire size tutorial needed here? Tire sizes are read as follows, using your size as an example!
    235= the width of the tread in millimeters, or 235mm
    60= the height of the sidewall in relation to the tread width, or 60 percent of 235mm (141mm)
    15= the diameter of the rim, or 15"
    So, will it fit? I can't say, although it is a very large tire for the front of an early A! Geof
    • Like Like x 1
    • GJSZ51
      96
      5
      Jan 25, 2013
      Local Time:
      7:23 AM
      235/60 - 15 on all 4 corners
      Mounted on SBP Coys C5 polished 15 x 7 with 4" offset. Suspension front and rear are non issues. Wheel lips clear by +3/4". Some concern with hard lock turns with loaded suspension but, I can certainly raise the front if needed.
      [​IMG]
    • GJSZ51
      96
      5
      Jan 25, 2013
      Local Time:
      7:23 AM
      Closer pictures
      [​IMG]
      [​IMG]
      [​IMG]
    • 65s
      65s Well-Known Member
      1,412
      27
      Dec 4, 2005
      Ottawa, Ontario
      Local Time:
      7:23 AM
      Great looking wheel/tire combo GJSZ51...I'm going to copy you one day!
    • Keith Mopar
      2,970
      1152
      May 15, 2005
      Calgary AB.
      Local Time:
      5:23 AM
      Looks real good, that tire fills in the wheel well in nicely.
      Great looking car to boot!
    • pishta
      pishta I know I'm right....
      18,606
      8086
      Oct 13, 2004
      Tustin, CA
      Local Time:
      4:23 AM
      thats the best big tire fitment pic I have seen. The backs look the closest at the front rocker.
      • Like Like x 1
