FS: Derale 17" Electric Fan and Adjustable Controller
Car Parts For Sale Archive
Thread Status:
  1. 70Duster440
    70Duster440 Well-Known Member
    2,710
    435
    Jan 8, 2006
    Washington
    Local Time:
    6:17 PM
    Contact Seller
    For Sale: Derale (#16217) 17" Electric Fan and (#16749) Adjustable Thermostatic Fan control. FREE SHIPPING.
    This is Derale's single largest high-output cooling fan. Rated at 2,400 cfm and is 2.61" thick. Can be used as pusher or puller. There are two options for mounting the fan: adjustable brackets or nylon mounting rods through the core.
    The Derale deluxe adjustable fan controller with pipe-threaded probe can be installed in intake manifold, block, or WP housing. Allows fan activation to adjust between 150 and 240 degrees F. Fan controller is suitable for race and street rod applications.
    I've also included a bushing required for the probe to fit Big-Block WP housings. I installed waterproof and Weather Pack connectors for easy installation and disconnects. Because of this you won't find a more "plug-n-play" installation for any A-Body. I bought it last Summer for my 440 Duster. Worked equally well as a mechanical fan on a 22" radiator but I want more cooling. There are no more than a couple of hours use so (with the exception of the terminals I installed) everything looks and functions like new. Connections are marked but original instructions are included.
    FYI, I mounted the controller on the core support in front of the battery with velcro. Wiring was routed along the stock harness. Sender wire followed the harness across the firewall and along the passenger side valve cover to the WP housing.
    Together, these items retail new for $209 at Summit Racing. Asking $129 with Free UPS Shipping in the USA. (Will ship from Washington state)
    Here's more information on the fan at Summit:
    http://store.summitracing.com/partdetail.asp?part=DER-16217&FROM=MG
    Here's more information on the controller at Summit:
    http://store.summitracing.com/partdetail.asp?part=DER-16749&FROM=MG
    Here's the installation instructions for the fan:
    http://static.summitracing.com/global/images/instructions/der-16217.pdf
  2. rednesss
    rednesss Well-Known Member
    1,449
    150
    Mar 4, 2006
    Eugene, OR
    Local Time:
    6:17 PM
    I might be interested. Will have to take a measuring tape to my cuda when I get home tonight.
  3. dusterdood
    dusterdood The Duster Guy
    1,640
    1
    Nov 25, 2005
    Rochester, NY
    Local Time:
    9:17 PM
    If redness doesn't take it, I'll go $100.
    Mike
  4. rednesss
    1,449
    150
    Mar 4, 2006
    Eugene, OR
    Local Time:
    6:17 PM
    Just measured, I think the March pulley cap takes away some clearance over stock or something. I only have about 2.25" of clearance, I guess I would have had more if I hadn't added a 3rd row to the rad when I had it rebuilt. Looks like from the picture that the 2.61" of clearance is pretty uniform on that fan. I'll have to pass. Oh well.
  5. shawns71rr
    shawns71rr Well-Known Member
    122
    0
    Aug 12, 2007
    sharpsville pa
    Local Time:
    9:17 PM
    if the fan is still for sale i will take it for $129. let me know...
  6. daves 72 dart
    daves 72 dart Well-Known Member
    184
    0
    Jul 16, 2005
    Waterloo,Iowa
    Local Time:
    7:17 PM
    i am next in line
  7. 70Duster440
    2,710
    435
    Jan 8, 2006
    Washington
    Local Time:
    6:17 PM
    PM and email sent to shawns71rr. Daves 72 Dart is next in line if the sale isn't completed, thanks.
  8. 70Duster440
    2,710
    435
    Jan 8, 2006
    Washington
    Local Time:
    6:17 PM
    Item is sold. Thanks to Shawn, FABO, and all the great folks here.
Thread Status:
